Author Topic: help on my horn  (Read 31556 times)
help on my horn
« on: January 10, 2006, 09:23:47 PM »
horn does not work...whee do i start? relay? if do where is the relay located?...do u suggest any  auto electical shop specialisin in american vehicles?
help on my horn
« Reply #1 on: January 10, 2006, 09:24:48 PM »
took it today to this guy on buffalo road...he was scratching hios head...he did not know where to start or the job is 2 small for him....so if u recommend some1...pls let me know
Offline MJ427
help on my horn
« Reply #2 on: January 10, 2006, 09:26:35 PM »
any decent auto electrican should be able to fix it
help on my horn
« Reply #3 on: January 10, 2006, 09:27:36 PM »
how long does it take to do it u rekon?
help on my horn
« Reply #4 on: January 10, 2006, 09:33:06 PM »
Joe... i think you need to place this thread in the pre 84 forum.
I recommend that you firstly start with taking the horn off, or testing it on the car like advised... that way you can figure out if the horn is okay or not... then work backwoods.
The horn may only need some adjusting, i recall on an old car i had in my younger days that they needed oiling...im not sure now..
Then if you know the horn is okay, then work on the wiring system.
I have the wiring diagram for my 69 Vette, i can copy it at work and give you a copy... it should be the same..
OK...;27
help on my horn
« Reply #5 on: January 10, 2006, 09:35:02 PM »
yes do that please....
OK...;27
help on my horn
« Reply #6 on: January 10, 2006, 09:50:57 PM »
OK...;27
Assuming you have checked for the obvious stuff like a blown fuse I would say Michael is on the money in my opinion.
Get a schematic if you can and follow the wiring and see if you have current at different points to pinpoint where the problem is.  Check to make sure the horn button has a good contact and then see if you have power at the horn and work your way back from there.
You should be able to do this with a test light and then go from there.
I'm sure a few of the other guys here will chime in.
help on my horn
« Reply #7 on: January 10, 2006, 09:54:54 PM »
thanks VO
Offline cosmicvette
help on my horn
« Reply #8 on: January 10, 2006, 10:02:20 PM »
yep, great advice VO and mike.
(Thread moved to Pre 1984)
help on my horn
« Reply #9 on: January 10, 2006, 11:06:16 PM »
check the "horn contact" which is directly under the cap of the middle of the steering wheel, it just prys off (carefully!). See that it makes contact with the other parts under it. I have dissassembled mine before its not that hard. Buy a steering wheel puller from Supacheap, I dont think they cost much and is always handy for use if you need it later. Basically it pulls the nut away from the column. then its easy to look and check all the contacts down further in the column. Just remember the order it came off! Like the others said also, see if a electrician can pin point the problem to see if the problem could be else where. Check the actual horn, a wire may not be contacting?
1969-74 Horn Contact Kit With Tilt-Telescopic Column
Fixes 90% Of Horn/Button Failures
Repair Parts And Replacement Parts
Most horn failures occur at the button due to broken horn contact buttons and contact brush insulators. This kit contains these parts plus the horn contact, spacer and screws.
Item#  38134
In Stock
$39.99  kit
Hopefully this will fix your horny problem!;41
help on my horn
« Reply #10 on: January 11, 2006, 12:20:21 AM »
Item#  38134
In Stock
$39.99  kit
I have already dont that andy...took it off and all the parts were inside it but do u know whther it is making contact assuming the part that ur were mentioning it...( i pushed it all the way with a needle and still nothing happened!!!
help on my horn
« Reply #11 on: January 11, 2006, 03:21:51 PM »
Its possible that a part maybe in the wrong place???? they tend to look a bit similar or one is upsidedown???
So you checked the actual horn? allwires conected?
I forget now which bits actually contact inside there, I think its that L shaped thing on the thing on the left/top of the picture? It touches another ring to make contact?
help on my horn
« Reply #12 on: January 11, 2006, 04:31:24 PM »
will have a look again thanks Andy
help on my horn
« Reply #13 on: January 12, 2006, 10:37:44 PM »
Joe... i got some pretty pictures from my assembly manual for you... hopefully they might also shed some light...
C u tommorow night bro...;29
M;36
help on my horn
« Reply #14 on: January 13, 2006, 01:05:04 AM »
M;36
kool thanks heaps bring it with you!!
help on my horn
« Reply #15 on: January 13, 2006, 11:28:26 PM »
I had a problem with my '77, except the horn was always on.  There is 1 wire that connects to the bit where the spring and plunger sits.  When you pro\ess the centre cap it must complete the circuit on the ring in the top left of the pic and sound the horn.
I never figured out how to fix it!  :b2  Good luck!
help on my horn
« Reply #16 on: January 13, 2006, 11:33:32 PM »
mate i have tried many times and no luck....so on monday will b taking it to the auto electr...it is not as easy...could b anything especially u havent got the tools...ur limited with tests
help on my horn
« Reply #17 on: January 16, 2006, 09:57:04 PM »
Did ya fix the horn?
If not I can help ya out.  Just completing a complete rewire on the 77.  Pretty well know all the in and outs of her nervius system now.
PS:- Yyour horn button earths out the feed to the horn relay.  In most cases all relays have active to their coil and any switches ground out the other side.  The horn wire runs down the steering column in the rainbow ribbon.  It in turn terminates at a mouth organ connector on the side of the steering column.  It's a simple matter of unplugging the mouth oran connector and checking the circuit there.
Did the horn always work?  Did it just stop?  Some history if you already have not fixed it.
help on my horn
« Reply #18 on: January 16, 2006, 10:25:43 PM »
hey Cam...
this morning i was supposed to take it to the elctrician cos simply i am not techy person....but the weather was so bad  so i have decided to postpone it...
i really appreciate your offer and i simply cant refuse it...if that means driving the car to a suitable place at your request  i am willing to do so.
u just let me know Cam.... i am also willing to pay u the favor back;38
let me know what u think...
oh and the history of the horn...it was not working wen i bought the car...but previous owner rekons it worked...mmm...;-)
help on my horn
« Reply #19 on: January 17, 2006, 08:33:37 PM »
No problem.  My vette is at my factory at Ingleburn, near Campbelltown.  That's where I have all my tools so there would be a good spot.  Pretty well any time as I'm always there, except this sunday the 22nd Jan, going to Castle Hill to have a sticky beak.
I'll e-mail my phone numbers.
