Author Topic: C3seat tracks  (Read 11887 times)
C3seat tracks
« on: December 28, 2012, 08:10:00 PM »
Has any one had any luck striping C3 seat tracks to overhaul them
There must be a way to pull them apart
BFit
Re: C3seat tracks
« Reply #1 on: December 29, 2012, 08:20:58 AM »
BFit
Hi Bob,
I had a spare one that I stripped to see what was involved. The rivets holding the mounting brackets on needed to be drilled out so the two sides could come apart. From memory there was a roller and ball bearing that fell out when I did get them apart.
It turned out to be more of a pain in the a-se then what it was worth.
I ended up refurbing my originals the best I could without stripping them. Cleanup, paint and re-lube.
One thing to note if you replace the tracks, 72 onwards use about 1"+ longer tracks then previous years and the rear mounting bracket will not line up.
Re: C3seat tracks
« Reply #2 on: December 29, 2012, 08:30:33 AM »
thanks for that mate
I spend some time looking and playing with the tracks to see how they are assembled
its not obvious not a great lot of info on the web either.
I will have another look later today
Today I am making a gig to fold up the rear seat mounts
