Author Topic: AIR Pump prototype(s)  (Read 17127 times)
Offline Stingraynut
    • www.myvette.20m.com
« on: November 20, 2003, 02:00:44 PM »
I’ve had another drama with my re-engineered AIR Pump – Previously I had new bearings put in and the fins removed, making it a freewheeler to support the belt. The pulley fell off after only 20 minutes driving. I sent it back and it was recently returned with a grub screw inserted to hold the pulley on. I re-fitted it last Thursday.
On Monday the guy that recommended the engineering firm in Brisbane for my AIR pump job, had his pump pulley fall off – with a different problem to mine.  I was immediately worried.
He had done 600kms with his, so I was hoping that they'd find the problem then I'd get mine fixed before it happened to me. Murphy decided that would be far too easy and struck ruthlessly.
On Tuesday morning, driving slowly at 45kph my   #$%^&^ AIR PUMP PULLEY FELL OFF !!!! - AGAIN !!!!AAAAAARRRGGGGHHH - It's becoming a familiar noise.
I rang John, (JOH Engineering Brisbane) he didn’t seem to want to take ownership of the problem, just advised me how to fix it, but actually had no idea why it happened.
The shaft was very tight and I couldn't spin it by fingers only with multi grips – there was a rough bumpy feel as if each roller bearing was going over bumps. I’ve travelled at most maybe 50kms. No bearing should go that quickly but it sure feels as if it has. It looks like the pump shaft bearing partially seized and the pulley was dragged off, the grub screw has broken off in the shaft and the part in the pulley has left a 1/4 turn spiral groove in the shaft.
Bending over the car by the side of the road, refitting my loaned pump in the blazing sun was no fun. I really didn't need this (who does ? )
I took the pump apart and found that the front bearing had almost seized, it was tight on the shaft and I couldn’t get it off . There appears to be a hard green substance, which I think is some kind of loctite all around the join of the shaft to the front of the bearing. I also found some wet green paste on the end of the shaft where there is no contact. Maybe the loctite has seeped into the bearing.
I took it to an engineering shop I've used before. There is still some unset green loctite about, and a strong possibility that some loctite strayed into the bearing causing the problem. The other alternative suggested by the engineer is that the shaft is too thick for the bearing and has caused the inner ball race to be too close to the outer - I don't think so, but he's going to check - it won't come off with a hammer but that could be the loctite that has oozed everywhere.
Because my pulley has come off twice, the aperture in the pulley that the shaft fits into is now not parallel - sort of opened out at the back end due to running half on/off just before falling off completely. I think the excess loctite was squirted in to fix this problem, as I think the pulley would have been loose on the shaft on the second re-fit.
I'm sure that John copied the original but the engineer here says there's not enough shaft protruding forwards to ensure a good fit. The front end of my shaft is a bit buggered due to the pulley being keelhauled off, so I'm getting a new shaft made, the benefit being that the hole in the pulley can be lathed back to parallel and the shaft can be lathed to fit that hole, which will be a couple of mm more than original. Rather than fitting another grub screw, he's planning to put a bolt through the centre from the front, which will ensure that it won't fall off completely again.
Thanks once more to vette obsessed who loaned me a pump, at least I can keep driving.
I can feel some more dollars anxious to leave my pocket
S’nut
Offline david_moore
« Reply #1 on: November 20, 2003, 10:20:02 PM »
Sorry to hear about the air pump S'nut, it has been for quite some time you have been wrestling with that murderous thing. I was going to do the same on my recently aquired '91 but will certainly leave it until you have had some success. Good luck with it mate I expect you will win in the end!!
Offline Stingraynut
« Reply #2 on: November 20, 2003, 11:56:55 PM »
Hi David - thanks for the good thoughts - yes, I feel like I've arrived on the set of 'Groundhog Day', catching taxi's home twice to collect my loaned pump and socket set etc and exchanging pumps on the roadside.
I have several other issues I want to deal with. JOH engineering is very lucky I don't live locally. I;m normally very calm....but....
I really wish I had used my local engineer, I'm sure I would have had the job done right first time. How hard is it to turn the pump into a freewheeler ? I'm not asking for rocket science here.
Have you posted any pics of yours yet ? I seem to remember it's a 91 . Any problems ?
As part of this issue I've been wondering what I would do if I had a breakdown that wasn't immediately fixable - I have RACQ insurance so would get a trailer tow although they have a very short distance limit.
As far as I can see, it wouldn't be possible to use a tow rope because of the low front .
Does anyone reading this have a simple solution ?
S'nut
« Reply #3 on: November 21, 2003, 09:44:45 AM »
Originally posted by StingraynutDoes anyone reading this have a simple solution ?
Flat bed is the only way to go unless you want to take the front clip off.
Offline Stingraynut
« Reply #4 on: November 21, 2003, 12:06:12 PM »
Hi 77CVT - thanks for the reply, does that mean that a 'trailer' tow when they put the front wheels on a jockey trailer will be no good because of the rear low ground clearance ?
How's your C4 going ? I read your post about the dyno results before/after removing rear MAF screen - very interesting - have you cracked 300hp yet ?
S'nut
« Reply #5 on: November 21, 2003, 06:00:27 PM »
Towing with the likes of mobi tow etc is ok but be careful putting on and off.  Flat bed is preferred.
Car is going well and more HP is only a matter of time!  :22
Offline david_moore
« Reply #6 on: November 21, 2003, 07:40:20 PM »
Minor set back with the new paint and the reassembly process is a little difficult 'cause I bought the car in pieces, other than that it is all going pretty good, need 4 tyres , got a shock at the cost of them. How is it going with the free wheelin' air pump , any luck yet?
Offline Stingraynut
« Reply #7 on: November 21, 2003, 08:02:40 PM »
I've spoken to the Cairns engineer today and he's made a new shaft which goes through the pulley and has a retaining bolt through the centre. (and new bearing) - looks like the bearing got full of locktight but can't see much point in having a go at the brisbane firm, it was a $180 job but I've also spent about $40 on postage and another $40 on a sepentine belt.
BTW the bearings were at least twice as big as the originals, sealed etc. The shaft through the gutted pump is almost an inch thick.
Tyres - go to www.tirerack.com - the most favoured 'tire' for the C4 is the Goodyear GS D3 very cheap in US. Unavailable here, I've had Goodyear trying to import some for me for months.
Kumho's are Aus$350 each here but it's not the Ecsta MX that everyone reckons are good. I would happily go into importing some Goodyears if we got up an order that would share the freight/Duty/Insurance  etc - if a few of us did it , it would be worth it.
If you are still putting your car together and haven't driven it then let me tell you that they don't hold the road in the wet, check my other threads out where people mention 'idling' around a race track corner in the wet while ricers fly past.
We don't want that.
S'nut
Offline smacko
    • http://members.dodo.net.au/~smack/
« Reply #8 on: December 03, 2003, 12:55:59 PM »
As some of you MAY know; and Stingraynut CERTAINLY DOES-I'm the guy who had the first prototype done (The unfolding dramas can be found somewhere on Corvette forum) and originally recommended the engineer to Stingraynut...(SORRY AGAIN MATE!)
In brief-With version THREE (Totalling FIVE attempts to get it right between stingraynut's and mine) now being PROVEN to be no good (Drew a felt-pen line across entire rear section) found shaft spins WITHIN inner bearing, even by hand and now sounds like a rusty gate!
JOH has said NO to refund.
I went to these guys because a few years back they DID do a great job in machining a cyl head off a Honda m/bike I rebuilt, but our recent experiances have proven that it was the machine, not the 'engineer' that was good!
Finally, now I'm having a real engineer from our club (Kieth Miller - KR Engineering) build me an 'eliminator', (that most guys in the states do when their pump starts wearing) out of stainless steel!
On of the guys on CF came up with what is NOW an obvious solution for anyone going down our path; have the shaft SOLIDLY mounted within case and just put a pulley on front of it, with its own bearing!  SIMPLE - something an engineer SHOULD have thought of before 'laymen' did !
Here's (Hopefully) a pic of prototype FIVE's rear with line proving it isn't done right!
Offline Stingraynut
« Reply #9 on: December 03, 2003, 01:16:36 PM »
Damm you, smacko !
on second thoughts, I'll take that back, much more use sending it this way -
Damm you JOH engineering !
It's not your fault smacko, recommendation is usually the best way to go and you were sure they were good or you wouldn't have had yours done at the same time. No probs.
Here's the link on Corvette Forum
 "http://forums.corvetteforum.com/zerothread?&id=692354&postid=1545798481#1545798481"  - for anyone that is tired of the daytime TV soaps and wants a Corvette story line instead
S'nut
« Reply #10 on: December 03, 2003, 01:29:32 PM »
