Author Topic: Rubber or Polyurthane?????  (Read 13605 times)
Offline MR 69ER
« on: August 18, 2003, 04:27:25 PM »
I am in the process of researching what type of suspension package would be best to buy in order to renew the front end of my 69 big block. Some have told me rubber bushes and others have said polyurthane. Can anyone shed any light on my situation?:20:20:20
« Reply #1 on: August 18, 2003, 05:33:30 PM »
I wouldn't hesitate in going with poly bushes. I've done my entire suspension, front and rear, with them. If you have any queries then ask away.
Offline MR 69ER
« Reply #2 on: August 18, 2003, 07:10:48 PM »
Well my intensions were always poly but since speaking to a couple of people several have mentioned that the poly ones were noisey (ie: squeek) i'm not sure how bad or after how long but that was their opinion and after looking around for the components i found Zip's selling the poly kit for $10.00 dearer than the rubber kit as apposed to everyone else how is at least $20-$30 more and i have started to think that not too many people might be buying the poly kits for this and other reasons. :20:20:20:20:20
« Reply #3 on: August 18, 2003, 08:20:08 PM »
I haven't heard a 'peep' out of my suspension since I changed over to poly bushes and before someone else tells you it's going to ride too harsh, it's quite ok in that area too. Aside from all that it's a job you can do at home on your own without the need for a press to push the rubber bushes and sleeves back into place. There are a few "tricks of the trade" for poly bushes, but nothing mind numbing.
I'd be more inclined to take it from people who have poly installed rather than from those who've heard it from a friend of a friend. or think they remember reading it in some magazine. Better still come and look at mine if you like.
And for your reading enjoyment here's an article on front suspension rebuilding that might be of some use as well.
Offline Adam
« Reply #4 on: August 19, 2003, 03:13:00 PM »
I also hear poly engine mounts are good.
;eek
I'm a highway staaaaaarrrr...
« Reply #5 on: August 19, 2003, 05:37:04 PM »
I had poly in the '77 since 2 1/2 years ago and no squeaks, no problems.  I would imagine they may squeak in a cold climate but it's never happened to me in winter.
Use grease when installing and buy the graphite impregnated ones (Energy Suspension).
Offline MR 69ER
« Reply #6 on: August 20, 2003, 09:00:44 AM »
Thanks Fellas I have just ordered the poly ones from Zip and should see them in a week or so. I thought poly was better but thought it a safer bet to throw it to you guys to chirn it around.
Steve:20:20:20:20:20
« Reply #7 on: August 20, 2003, 12:00:50 PM »
Steve...Did you order the poly boots for the ball joints and tie rods as well? They're a very good addition while you're under there doing the front end. Sure beats watching the old rubber ones deteriorate where the poly ones would last for years longer.
