Author Topic: Headlight assembly Vacuum leak  (Read 10682 times)
Offline SlySilvervette
« on: September 05, 2008, 08:52:49 PM »
Hey guys. I'm wanting to remove the 2 off headlight assemblies for the replacement of diaphram and seals to fix vacuum leaks, fingers crossed.
Can ne1 help thanks.
« Reply #1 on: September 05, 2008, 09:12:06 PM »
What year?
I have this for a 77 CLICK ME
« Reply #2 on: September 05, 2008, 11:27:52 PM »
You only have to remove the actuators if you're talking about what I think you are.
This link may help:
http://www.corvettemagazine.com/content/view/18/28/
« Reply #3 on: September 06, 2008, 10:51:34 AM »
This link may help:
Thank you hopefully this may help. At the moment there is a loud hissing noise coming from that area so I disconnected the vacuum line to the headlights, now I will set aside some time to investigate.
I also have some sideways movement of one of the headlight assemblies, is this a common problem as well or is it a 1 off thing I need to investigate. Thanks for your help
« Reply #4 on: September 06, 2008, 10:53:03 AM »
Whoops new on here I think I may have replied in the wrong area, Thank you for your help.
« Reply #5 on: September 06, 2008, 10:28:17 PM »
sly get hold of a vacum gauge.....start at the begining and see where you losing pressure....that will be where the leak is if you have one.
