Author Topic: Removal and install pics.  (Read 23672 times)
Offline rebel
« on: June 16, 2003, 02:14:38 PM »
Folks,
Has anyone ever had the experience with corrosion or other contaminants in the fuel tank of their C3 ... ?
Besides the replacement of the tank, what other ideas are out there regarding a solution ?
Do tanks clean well ... and are they expensive ?
Appreciate any comments ..
Thanx ...
Offline johnny86convert
« Reply #1 on: June 16, 2003, 02:51:12 PM »
been  there  done  this  alot,IE  take  the  tank  out  and  fixed  holes,  didn't  work.  so  replaced  at  great  expense. But  taking  out  one  is  relatively  easy,  just  remember  to  take  mufflers  off,  the  long  way  at  the  start  is  the  quicker  way  at  the  end  when  it  comes  to  putting  it  back,  most  fiddly  part  is  centreing  the  filler  cap  and  making  sure  the  straps(metal)  are  tight,also  the  return  line  on  the  near  side  is  fiddly  connecting  back  up,all  in  all  don;t  rush  it  and  you'll  succeed  ;);););)
« Reply #2 on: June 16, 2003, 03:04:03 PM »
It seems a fairly straight forard sort of job, but with the usual fiddy bit entrained along with it. JH has just about covered them all, but would include the metal tank cover on the list of PITA items.
« Reply #3 on: June 17, 2003, 11:26:41 AM »
Um...... if taking the tank out make sure it is near empty!  Don't ask me why I know this is a good thing to do. ;laugh
Also, replace the rubber fuel lines while you're there.
Offline rebel
« Reply #4 on: June 18, 2003, 09:25:52 PM »
hmmm .. interesting there's no mention of the spare and cover as well ...
The best long term solution is to replace the tank with a new one. That's obviously a more expensive option and at the moment that's not appropriate. Alternatives include draining and cleaning, having a someone like JayJays in Arncliffe cut it, re coat and seal at a lower cost .... or .... placing a heavy duty magnet at the base of the tank to contain any metal filings, installing a fine, good quality filter in the fuel line and simply replacing that every few months whilst fueling up at the qrtr tank level.
It appears this prob dates back to pre Convention and I was surprised that only one of the fuel compartments in the carb was working.
Thanx for comments ...
« Reply #5 on: June 18, 2003, 10:41:07 PM »
SR Perf fixed mine Rebel.About a year ago my tank was leaking,he patched it up and hasnt leaked since!The holes were created by the metal surround strapes rubbing on the tank!So if you fix your tank yourself or use somebody else,make sure you got some rubber in between.Rubber that doesnt melt ! just incase when your filling and the petrol over flows .Mine spills over on the odd occassion and has melted the rubber a bit!
« Reply #6 on: June 18, 2003, 10:46:27 PM »
just another  thought  that  arrived  in  the way  of a  rough  running  big  block  with a  quadrajet  carbie,  was a  dirty  fuel  filter  on  the  incoming  fuel  line  in  the  front  of  the  carbie,was  blocked  full  of  crap  so  we  gave  it  the  flick  and  put an  inline  sports  filter  clamped  to  the  inside  of  the  guard(  well  away  from  getting  overheated  near  the  motor)  never  had  another  problem  with  crap  coming  from  the  tank,  even  after  fitting a  new  tank (  still  don;t  trust  petrol  stations););););););)  by  the  way  best  guy  for  overhauling  and  modifying  quadrajets  is  sams  performance  padstow
« Reply #7 on: June 19, 2003, 08:59:39 AM »
One would assume you would know to take that off first!  :b2:b2:b2
Offline Adam
« Reply #8 on: July 25, 2003, 09:26:05 PM »
Rebel- I have a spare vette tank lying around:p I was suprised it was made of plastic, very light. Anyway, I'll lend it to you if your desperate, still has some optimax in it too! Although the tank only a few years younger than yours!
Adam
I'm a highway staaaaaarrrr...
Offline rebel
« Reply #9 on: July 25, 2003, 09:46:56 PM »
Thanx WR, appreciate the offer.
I should have posted an update but on closer inspection it turned out the tank was full of sand and other debris. A good clean and a vacuum seems to have solved the problem for now. I also fitted a fine fuel filter in line and will keep an eye on that every few months or so to see how it goes.
Thanx to everyone for the responses here too!
Offline onya
« Reply #10 on: July 25, 2003, 10:04:07 PM »
Maybe you could replace the rubber strip around the tank with a nylon strip. Just a thought;27
« Reply #11 on: July 26, 2003, 09:39:04 AM »
I believe there is a product you can use to line your tank with.....a liquid that is sloshed around inside to coat the innards and protect it from any corrosion.
Offline david_moore
« Reply #12 on: July 26, 2003, 08:04:35 PM »
AT the risk of sounding like a smart arse,
KEEP YOUR TANK FULL WHEN NOT IN USE!!! :evil
Of petrol that is!:};35
Offline Adam
« Reply #13 on: July 26, 2003, 08:34:00 PM »
On aircraft there is a tap on the bottom of the tank, the point is, b4 each flight u let out some fuel to take out any water and misc. that may be there. Perhaps an idea for the hardcore motorist.
« Reply #14 on: July 27, 2003, 01:40:33 PM »
Try here for a comprehensive how-to on tank removal and re-installation. Nobody covers his work more thoroughly than Scott81.
http://www.c3sharktank.com/tech2/rearsusp/rear4.html
You might want to check out the rest of his vast range of info on his web page. Check my sig for the link.
« Reply #15 on: July 28, 2003, 09:05:09 AM »
... the tank was full of sand and other debris. ....
Sand!!??   :mmm:mmm:mmm;eek;eek;eek
Offline Adam
« Reply #16 on: July 28, 2003, 06:24:21 PM »
U know, sand, rocks, birds...
Make sure you have a lockable cap for that matter as anyone can slip anything in yer tank.
« Reply #17 on: July 28, 2003, 08:34:14 PM »
There's nothing like driving past the Kurnell sandhills every working day to test the seals on your car.;eek
Offline Adam
« Reply #18 on: July 28, 2003, 10:43:53 PM »
Yea, all those herbs an spices can eat thru the vinyl weatherstrips
Offline rebel
« Reply #19 on: July 29, 2003, 10:18:10 PM »
The guy formerly known as 77CVT ... ;-)
Not sure how the sand got to be there but I can guess that when it went through the original restore some years back, the cap was off whilst the panel beater sanded back the panels etc. The previous owner to me had the thing garaged for most of the time he had it so he wouldn't have noticed a prob.
