Author Topic: Add a Head Light Relay Circiuit  (Read 8877 times)
« on: June 28, 2006, 12:05:02 PM »
Found this on another site.
One note though.  Do Not use the jumper option.  That is not quite correct but the rest is.
[img=417x454]http://www.corvettevalley.com/gallery/data/504/1qgaya.jpg[/img]
Offline steve_79
« Reply #1 on: November 24, 2006, 08:13:35 PM »
I was about to ask what's wrong with the jumper option, but i think i figured it out.
  Is it that your dimmer switch would now be trying to power the high beam directly from a low capacity circuit thus possibly blowing a fuse or burning out the wiring?
  If so, wouldn't a large diode ( such as in my invisible auto resetting killswitch on the 4by ) sort out this problem??
  Steve
« Reply #2 on: November 24, 2006, 08:36:10 PM »
Yes, the problem is the dimmer switch, as labeled on drawing (low/high beam switch or dip switch), when on low beam the high beam comes on via the dimmer switch.  Hence dimmer switch carrys full load current.  A diode in the jumper would resolve the problem of the back feed.
[/align][/color]
