Idler Pulley and bracket finished
Started by Cameron 77C3, November 28, 2005, 08:59:17 PM
Cameron 77C3
Following on from my last post on the steering.
If ya recall I had a problem with the alternator belt hitting the new power steering pump and was going to machine up and idle pulley and bracket.
I purchaced the idler pulley from the local bearing supplier and had the bracket machined up.
The new idler pulley is bolted to the Billet Specialities Alternator Bracket using this bracket machined from billet aluminium. It was machined to follow the contours of the alternator bracket to ensure that it sat flat and did not rock. It is held in place by a single bolt that goes through it and the alternator bracket and into the head. Small tabs that resulted from the machining process act as location tabs and prevent it from turning on the alternator bracket during bolt up.
As you can see here the pulley belt now clears the power steering pump with room to spare
Here you can just see the location tab sitting in the valley of the Alternator Bracket
MADVET
Great piece of engineering Cam. It also increases the belts' surface area against the crank and alternator pulley reducing the chance of it slipping.:v
NOW WE'RE TORQUING!
TIPPA
What a great solution! Looks factory too. Is the pulley bearing an interference fit on the bracket?
69 DIRTY RAT
Your up yourself!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!;41
Its very good!:spook
Cameron 77C3
QuoteOriginally posted by TIPPA
Hi Tippa.  No the pulley is a slip fit.  The spigot that the pulley fits on is a few thou shorter than the thickness of the bearing.  When the the locking bolt is done up tight the large flat washer under the bolt head clamps the bearing up against the back of the bracket.  This ensures it does not spin on the spigot and when it comes time to replace it no bearing pulleys will be required.  Allows for easy replacement out on the road.
QuoteOriginally posted by 69 DIRTY RAT
.....................:spook
:v:};);35:bold:) ;-- ;39;39
MJ427
SMF spam blocked by CleanTalk
