Author Topic: Power windows  (Read 14053 times)
Offline cve77e1984
Power windows
« on: September 01, 2005, 10:07:18 PM »
Both my windows have failed to work, first the pasanger side now the drivers side. can any one give me some advice, or is there a way to at least get them up manualy.
Offline cosmicvette
Power windows
« Reply #1 on: September 01, 2005, 11:11:43 PM »
could it be a fuse??
why would both stop working like that?
Power windows
« Reply #2 on: September 02, 2005, 11:32:29 AM »
I'd check the fuse first, then the switch with a test light.
Power windows
« Reply #3 on: September 02, 2005, 06:08:24 PM »
Hmmm.  Not sure on C4's, but under the centre console in C3's there is a relay that powers up once the ignition is on.  This realy then allows power to the switches for the windows.  If you have this relay you can here it click in when the key is turned to ignition.  Just a thought.
As I said I'm not sure if this is in a C4.
Let us know how you go.
Offline Thunder Kiss
Power windows
« Reply #4 on: September 02, 2005, 07:28:45 PM »
Can you hear the window motor working while you operate the switch?
Early C4s have a power window ribbon made from plastic. after 15 or so years this ribbon becomes brittle and breaks.  Replacements are around US$20.
Here is what it looks like:
It is also common for switches to fail.  They're around US$6.
Power windows
« Reply #5 on: September 02, 2005, 10:08:23 PM »
Bugger me, didn't they change alot from C3's to C4's.  Does that ribbon replace the whole mechanical actuator that's in the C3's?  I mean does it actually lift the glass up and down?
Offline cve77e1984
Power windows
« Reply #6 on: September 03, 2005, 09:56:18 PM »
I fixed it.
Spent all day checking the fuse testing swiches and ground, pull all sorts of thing apart to finaly find out that the conector to the motor had come lose (strange that they both had, all i can put it down to is from when i had it resprayed).
Thanks everyone for all the help.
See you a Fox
Power windows
« Reply #7 on: September 03, 2005, 10:04:55 PM »
Well done squire.  Nice and cheap fix.
Offline cve77e1984
Power windows
« Reply #8 on: September 03, 2005, 10:11:58 PM »
It all ways good went a repair job dosn't cost you. now just have to put evry thing back.
Offline daniel42au
    • members.ozemail.com.au/~daniel42au
Power windows
« Reply #9 on: August 27, 2006, 05:08:43 PM »
Not only did it cost you nothing, you got an afternoon of enjoyment too.
Actually, I suspect statistically panel beaters are right up there when it comes creating electrical problems in the cars they 'fix'.
