Author Topic: Brakes. Need new calipers or rebuilds  (Read 30789 times)
« on: June 13, 2005, 05:01:55 PM »
Hi guys.  As I suspected, when I hooked up the new brake system the old callipers started to weep.
So what do you guys recommended?.  I can either get the old ones rebuilt.  Any suggestions on who to do the work? OR
Buy new callipers.  I Like the idea of stainless pistons etc.  You know, some high quality/performance gear.
Any serious input here would be greatly appreciated.
Offline TIPPA
« Reply #1 on: June 13, 2005, 06:31:27 PM »
I had my fronts rebuilt thru Classic Chev. their guy machines them and fits stainless sleeves, as most brake shops can do, but also loctites the sleeves in and when assembled, and then pressure tests them to ensure there is no weeping between the casting and the sleeve. good peace of mind IMHO. Pretty expensive though... think i paid around $800...:b4
Offline TIPPA
« Reply #2 on: June 13, 2005, 06:43:35 PM »
Forgot to add for that $ were new seals of course and, due to pitting corrosion, all new pistons. Like i said, prob not the cheapest but peace of mind none the less.:b2
« Reply #3 on: June 13, 2005, 07:05:16 PM »
I'm thinking of these.CLICK HERE for article on "Stainless Steel Brakes Corporation's " Aluminium brake calipers.
Expensive litte suckers.  About RRP of 1500 US Dollars for all four wheels, 2 kits.  I'm waiting on a reply from them to see if they have an agent in Australia. [kit includes all that is shown in the picture]
This is the type of thing I'm after.
Having said that.  How long ago did you get yours done and did you have any trouble bleeding them.  [You know the old problem of air being sucked back in past the seals]
Offline mick
« Reply #4 on: June 13, 2005, 07:25:06 PM »
Try these guys Cam,
                                 I found them on the net of few weeks ago and got a catalogue sent to me looked pretty high quality.
www.VBandP.com
Mick
« Reply #5 on: June 13, 2005, 07:26:52 PM »
Originally posted by mick
Try these guys Cam,
www.VBandP.com
Mick
I'll go check them out now.  Thanks.  Keep the suggestions coming guys.  Many Thanks.
« Reply #6 on: June 13, 2005, 07:32:22 PM »
get the aluminium ones! and get some bigger/better rotors too! Thats what I'll be doing (oops I let it slip!). I'm hoping to get 14 inch rotors Front 13in back. But you can get some great rotors in 12 inch + the aluminium calipers combo's...youll stop on a dime! Big money but it'll put you in the 21st century! But the cheapest way is to stainless re-sleeve.But again you have to make sure that there is holes around the sleeves,otherwise its useless putting new sleeves in...cause theyll still leak!
Offline mick
« Reply #7 on: June 13, 2005, 07:32:25 PM »
Just had a quick read of the catalogue they have new replacement calipers for $469.95 US for a set of 4 or heavy duty delco for $559.95 US a set.
Offline TIPPA
« Reply #8 on: June 13, 2005, 07:40:54 PM »
Prob about 6 months ago Cam. Heard that they can be tricky to bleed but i didn't have any probs. Only thing was trapped air using gravity bleeding but nothing a bit of patience couldn't solve. Never had probs of air being sucked back thru the seals, especially with the rebuilt calipers with new seals. Still trying to justify the cost of a pressure bleeder to myself though... Would make life a bit easier (but for around $400 for a pressurising {hand pump or compressor} canister type)... :b4
« Reply #9 on: June 13, 2005, 07:41:19 PM »
Want more......Baer,Muskegonbrake.com,vansteel,reddevilbrakes.com,wilwood
« Reply #10 on: June 13, 2005, 07:41:46 PM »
Yeah I just checked it out.  Many thanks.  They sure do have some gear but I'm mainly after some high performance gear.
Many Thanks for your time and effort.
Offline TIPPA
« Reply #11 on: June 13, 2005, 07:43:01 PM »
Now those sound like the go! Works out similar money and they are totally brand new. Better choice for sure.
« Reply #12 on: June 13, 2005, 07:44:26 PM »
Say what?!  Are these guys local or US?
Andy,  If you go bigger rotors, then your going bigger wheels, yes/no?
« Reply #13 on: June 13, 2005, 07:50:09 PM »
I used speed bleeders on the calipers today and bleed all four from empty in an hour or so just by pumping the brake pedal.
Yeah I agree.  If I can I would like to go Aluminium/stainless.  See what I find and how much.
Anybody know of  Aussie makers or importers of aluminium calipers?
Keep them coming guys.  I want as many options as possible.
Thanks.
Offline Thunder Kiss
« Reply #14 on: June 13, 2005, 08:45:35 PM »
You could try Hoppers Stoppers.  I have their DBA/PBR twin piston upgrade on the front of my car.
Otherwise if you want something a little more exotic try Cebco who are agents for Brembo and AP Racing.  I don't know if they have any Corvette specific packages though.
« Reply #15 on: June 13, 2005, 09:02:17 PM »
Thanks.  I have e-mailed them to see what they have got.
Great responce guys.  Keep em coming.    Thanks
« Reply #16 on: June 13, 2005, 09:06:24 PM »
Cant say too much Cam...only to say they are 335 x 12 wide!
« Reply #17 on: June 13, 2005, 09:27:15 PM »
Want I meant was, "To go to bigger dia. rotors you need bigger wheels?"
I want to stick with my standard wheels for the moment.  I am looking at better rotors but I was under the impression I can't go to much bigger rotors without going to larger wheels?
Offline TIPPA
« Reply #18 on: June 13, 2005, 09:47:16 PM »
I'm sure there would be others who, unlike me, would definitely know, but assuming yours has the same wheels as mine i've heard what you have- our standard calipers fill our standard wheels with not much room to spare. i haven't measured them but am sure a quick comparison between the wheel inner dia and the distance from the axle/stub axle to the outermost part of the caliper will give you your clearance ;40
« Reply #19 on: June 13, 2005, 10:16:44 PM »
I'm sure there would be others who, unlike me, would definitely know, ....... ;40
Yeah I'm sure but I thought I would ask just incase I missed out on something new.  If you read the article I posted the link to earlier you can see that the new calipers just fit with the new 12" rotors.
Keep any Ideas coming guys.  Thanks
