Technical Tips
Transmissions - Differentials
C2 Corvette Differential Rebuild
Poll
Who would you recommend to rebuild a C2 Corvette Differential in NSW? Please advise.
Advise
0 (0%)
Recommendations
0 (0%)
Total Members Voted:
0
Topic: C2 Corvette Differential Rebuild (Read 20187 times)
Cmaces
Newbie
I'm new here
May 01, 2021, 09:07:06 AM »
I've had my Diff rebuilt (No Names Mentioned), new posi clutches, side yokes, bearings, and etc. The issue is I still have excessive side yoke play, at least 5mm play.
Who does a good job in NSW or Australia if need be?
Don't talk of dust and roses
Global Moderator
Two one thousands
Mood: Honey reinforced
Car: Yes
Re: C2 Corvette Differential Rebuild
May 01, 2021, 01:07:01 PM »
You should take it back to who ever did the job
If the couch packs are not set up to the correctly the you get end play,
There are other issues that can be in play here.
Ring me my number is in the contact info
Ps you have pm
rosco
Four Barrel
May 02, 2021, 05:23:39 PM »
Dif trans at South Windsor.
There the only ones I would let touch a dif or transmission.
Regards Rosco
sirfixalot
Fuel Injected
Reply #3 on:
May 03, 2021, 02:19:25 PM »
I used Diff Technics at Kogarah had no problems in about 5 years
Cmaces
Newbie
I'm new here
Reply #4 on:
May 05, 2021, 06:05:45 PM »
Thanks, guys
Technical Tips
