Author Topic: C3 Rack and Pinion Steering  (Read 23970 times)
Offline Chuky68
« on: April 03, 2020, 05:45:42 PM »
Hi Clubbers,
I am thinking of putting a RHD rack and pinion steering in my BB C3 corvette any info such as advice,  tips, hints issues, photos etc. you can share would be greatly appreciated.
Re: C3 Rack and Pinion Steering
« Reply #1 on: April 03, 2020, 07:01:18 PM »
Be interesting to see the build, RHD rack will not be an off the shelf purchase, have you talked to an engineer to see if they will sign of on that mod.
Offline RHD.68.l89
    • www.invisiblecarbras.com.au
« Reply #2 on: April 04, 2020, 08:21:59 AM »
Easiest way is use a Camira centre take off rack and mirror the steeroids conversion. You need the long travel to get lock. I used a Commodore rack with engineer shortened arms. While I was doing it I got rid of the bumpsteer and added achermann angles. it was a lot easier with a bare chassis and no springs.
« Reply #3 on: April 04, 2020, 11:08:16 PM »
Yes an off the shelf for BB are available, but the RHD part ?
Whether they would sell you a kit less the rack ?
I would like to do R&P on my 78,  of course only a SBC, but is RHD.
We did have a member with a C3 who built a well engineered R&P set up, he was over Coogee way, cant remember his name.
He had documented his whole process c/w pics, but have lost contact .
Keep us informed.
« Reply #4 on: April 04, 2020, 11:27:54 PM »
Chuck what is wrong with the current steering system .
« Reply #5 on: April 05, 2020, 10:15:04 AM »
Retoricle (or is it reticulating) question Bfit.
I started on an EK 3 on the tree Station Wagon. It had Power Nothing.
Said no thanks Dad - went to a learn to drive school and a Mini Cooper S. What a difference.
Changed instructor to a Mini Clubman, I've had or driven Mini's, E types, MG'''ss, Austins/Morrises even a Leyland V8.
Oh! And I forgot Phill Lucas's Ford GTHO Ph3, what a buzz, down the old Liddel Highway with a car trailer on the back at (you dont want to know) Mph.
A lot of the above are manual R&P steering, heavy with wide tyres at low speed, but still better than the old reticulating ball.
« Reply #6 on: April 07, 2020, 03:34:34 PM »
Done a bit of Googling
Surprised to see quiet a few Aust Sellers of power and manual R&Pinion for both RHD and left hook.
Interesting.
« Reply #7 on: April 07, 2020, 04:13:03 PM »
Anyone fitting, a rack and pinion to a stock C3 corvette front suspension is deluding themselves if they think it will work better that the stock draglink design.
 If they want a corvette with rack and pinion steering , Buy a c4
« Reply #8 on: April 08, 2020, 10:16:18 AM »
Haven't seen a good set up yet lack of turning circle. Acute angles on uni joints from column to rack. Rack gets mounted under motor then tie rod ends have to be replaced with heim joints & spaced down to correct bump steer tells me rack needs to go higher but engine wont allow it to. Show me a good set up.
