Author Topic: New guy on the Central Coast NSW  (Read 38472 times)
Offline Old guy
  • Car: c3 1980 Vette
« on: November 01, 2019, 05:28:56 PM »
Howdy. Just got a vette and will be reading up to get a few things done. Needing someone that knows these cars on the coast. A/C specialist too. Any recommendations? Cheers :cheers:
Re: New guy on the Central Coast NSW
« Reply #1 on: November 01, 2019, 09:26:08 PM »
I think Dave is crook and the Cox's are away, but I'm sure someone up there will give you some good advise.
Keep watching....
Offline Old guy
« Reply #2 on: November 02, 2019, 07:00:46 AM »
Offline toyvet
  • Club Plate Registrar
« Reply #3 on: November 02, 2019, 10:16:13 AM »
Hello we have a club member that specialises  in Corvette and performance cars but he is in Sydney SR performance he can also fix your air conditioner problem —number is 0439901560 regards Jorge vette club
Offline Old guy
« Reply #4 on: November 03, 2019, 09:23:02 AM »
Offline Old guy
« Reply #5 on: December 03, 2019, 07:48:19 AM »
Anyone? Will eventually travel to Sydney, if needs be, but hoping there's someone up here  :thumb:
« Reply #6 on: December 03, 2019, 07:21:50 PM »
Contact the Northern Delegate: https://nswcorvettes.com.au/committee.htm
Offline Old guy
« Reply #7 on: February 16, 2020, 06:57:53 PM »
Long Jetty Automotive Engineering seems to be the preferred choice for Coasties. Ph 4332 5570. 483 The Entrance Rd, Long Jetty
« Reply #8 on: February 17, 2020, 09:15:59 PM »
I dont know if Ron Missen still has a shop at Gosford.
I'll visit his Ingleburn shop tomorrow for his Mechanics considered opinion on  SBC plumbing issue.
Regards.
Offline Old guy
« Reply #9 on: February 17, 2020, 09:18:52 PM »
He was.  Not sure if he still is as I havent heard anything about him for a year or two.
« Reply #10 on: February 17, 2020, 10:12:25 PM »
Regards.
Really.
It’s a SB been around since the early 50’s , what’s the problem.
SYDNEY water may be ably to help.
« Reply #11 on: March 29, 2021, 09:49:57 AM »
I’ll ask a member who would know the system well ,if he can assist , I’ll be back to you
« Reply #12 on: March 30, 2021, 07:33:50 AM »
AC can get real expensive real quick you haven't given much away what year  car? what are your issues? Is AC complete ?
Offline Old guy
« Reply #13 on: March 30, 2021, 02:43:04 PM »
71 big block, auto. a/c was removed (prior owner), to rebuild engine. I received it all (brackets, condensor, compressor, etc) in boxes.
« Reply #14 on: March 30, 2021, 10:08:36 PM »
Question.
1. Has it had left right conversion.
2. Cant remember AC for 71 but it will require at LEAST either a new Reciever Drier or an Accumulator.
Rec drier's are pretty straight forward, but if its an accumulator style system then research and get a Holden type which is set up for RH drive - ergo AC is on LH side, you will also need a new pipe/hose set up.
Don't throw away old pipes, hoses fittings, crimped fittings can be cut open and reused with a new ferrule.
Just did a quick look - its a POA type system, requires a new Reciever Drier, maybe a POA valve and or an expansion valve.
R12 is no longer available, and its replacement R134A is being phased out, there is another rather long winded Gas or you can opt for Hi-Chill -30. I've used this in two (2) C4 90's and soon in a C4 87 and hopefully down the track in a C3 78.
Hi-chill is effective, runs at lower cylinder & compressor pressures, does not require any special stuff, it is effectively a drop in replacement for R12 or 134A and requires far less volumn of gas.
If you take it to a good Tech, he should flush out and clean everthing, that includes oils, dirt etc etc he will then measure into each component an amount of new oil (I think a PAG Oil) make new lines, connect up, vacuum down, then if no leaks recharge with gas.
Then you will be cool. As long as the under floor insulation and underfelt and carpet has been replaced and of course there are NO holes anywhere in the fire wall. An 1/8" hole in the fire wall even with carpet over it will heat the cabin up to an inferno. Good luck.
« Reply #15 on: April 02, 2021, 10:12:11 AM »
For a 71 it is at least a 3 stage process to get AC going. 1 all parts need to be fitted up to car, plumb up water and AC pipes. 2 Vacuum system for internal doors and console control and cables will all need to be tested repaired as required,electrical for fan control and speeds tested.3 Gas up system and test and hope no leaks. Possible problems may require new hoses for AC brittle/porus,Seals gone hard  in compressor, I had one rebuilt about 15 years ago was $500, is now on shelf retired, have retrofitted with new sanden 508,heater core defective requires removal of R/hand dash to replace.All bits you have are unknown quantity so will all need to be checked /tested and even if tested ok may fail soon after commisioning AC. It is very labour intensive to fix and can get real expensive real quick if you are paying someone to do all work.Only viable way is to complete as much work yourself as you can, there is heaps of info on net how to do things, test,repair.Plus at the end of the day you will know a bit about your car
Offline kevinh
  • Mood: Depressed
  • Car: 76 Stingray
« Reply #16 on: September 07, 2022, 01:51:41 PM »
Hi all - another new guy, this time in the Hunter region.  Happy to travel anywhere in NSW to someone that can swap out the body mount rubbers that have perished on a C3...?  Cheers for any advice, it's above my abilities to do at home - particularly without access to a hoist.
Offline toyvet
« Reply #17 on: September 07, 2022, 06:30:50 PM »
HELL NEW GUY
CALL STEVE SHARKIE AT SR PERFORMANCE 0439901560 HE IS A CLUB MEMBER THEY SPECIALICE ON CORVETTES AND PERFORMANCE CARS
THEY WILL HELP YOU WITH YOUR PROBLEM
REGARDS
JORGE ( HISTORIC PLATE REGISTRAR
