Vf GTS
Started by bfit, April 27, 2019, 12:21:45 PM
would anyone on this site have a VF GTS .
I'm looing for a dimension  see photo
Centre line of bolt to ground, this cradle carries the 250mm diff aluminium out bearing hubs.
The earlier VE cradle mounting for the bottom control arm in a different setup.
Scott
You need to join up at performanceforums.  It's about the only aussie car forum around that hasn't died, and there are a lot of smart older blokes (ie over 30) on there doing silly things with cars.
 Mate I have tried to join
I just can't get there online rego sorted on the Ipad
ill try on a computer when I get to work
Scott
Username is Bfit?  I'll send a message as they need approval I believe.
yes Scott
I got through the registration on a PC
Scott
Cool, the newest member is listed as joining a few weeks back, which wouldn't be true.
it would appear that the moderators there don't check new applications to  often.
Now for my dimension .
working backward from the wheel and tyre dimension. I would suspect the dimension im looking for is
On a stock VF  about 240mm
on a VF GTS  about 220 mm
I have an appointment this Friday to take a few measurements on a VE GTS .not the exact same rear cradle buy the style and arrangement  are similar enough to make some observation in relation to the overall system.
used in the VF gts .
I'm interested to know if the stock  Toe adjust rod is parallel to the ground a ride height. I would think it should be however I can see reasons why  is could  be angled upwards  from the cradle pivot to the wheel carrier mounting point.
SMF spam blocked by CleanTalk
