Author Topic: C6 evaporative emission control system vent valve  (Read 17098 times)
Offline jagsy
  • Mood: Always happy
« on: March 25, 2019, 04:54:18 PM »
FYI
Had a engine code pop up over the weekend P0449 DTC which means that the evaporative emission control system vent valve could have failed.
Seems to be a common failure.
Ordered part (and additional wiring harness for new part!) so will see when it arrives.
I read the valve only operates at cold engine start up cycle and I can clear code once engine is warm.
Re: C6 evaporative emission control system vent valve
« Reply #1 on: March 25, 2019, 05:03:46 PM »
Jagsy
Check your fuel cap is working correctly.
If you have a spare swap it over
Offline jagsy
« Reply #2 on: March 25, 2019, 06:49:21 PM »
Arh ok, will do, don’t have spare but willcheck it’s on properly
Offline jagsy
« Reply #3 on: March 25, 2019, 07:31:41 PM »
Ps Bfit, is there a way to test if fuel cap is working properly if I don’t have a spare?
« Reply #4 on: March 25, 2019, 10:52:50 PM »
I’ll ring in the morning
