Author Topic: GMH GTS/SS steering wheel swap  (Read 22096 times)
Offline Darylle
« on: December 27, 2016, 11:04:52 PM »
Hi everyone
Could the above s/wheel be interchange with the c3 standard set up?
Re: GMH GTS/SS steering wheel swap
« Reply #1 on: December 28, 2016, 08:30:57 AM »
You would have to check the pitch circle of hub & also the new wheel. You will also have to check where the holes are drilled in wheel some are drilled @ 12 & 6 o clock others are drilled @ 11  & 1 o clock. If  you turn the hub to suit the wheel it will then cause  your blinkers not to cancel on one side.The other problem you will have is the tele function on the column incorporating a locking method.
Could be done but a lot of work have done a couple with aftermarket wheels
Offline rosco
« Reply #2 on: December 29, 2016, 09:22:16 AM »
Nope will not fit if it's the black sports wheel from the HQ onwards.
HK to Ht will fit as will the early LC Toranas.
Regards Rosco
« Reply #3 on: December 29, 2016, 09:50:16 AM »
If it's a genuine HQss wheel it would be worth quite a bit . (sell it n buy an original vette wheel or after market replicia ) much easier
Offline Darylle
« Reply #4 on: December 29, 2016, 11:08:03 AM »
Thanks for the replies
What about a "vega" aftermarket wheel, I read somewhere they are the same.
Offline rosco
« Reply #5 on: December 29, 2016, 11:23:24 AM »
https://willcoxcorvette.com/corvette-steering-wheel-mahogany-chrome-3-spoke-68-82-exc-76
Here you go bolts straight up looks great and cheap as chips . :grin:
Rosco
« Reply #6 on: December 29, 2016, 03:43:16 PM »
Good one Rosco - that looks excellent.
Offline Darylle
« Reply #7 on: December 30, 2016, 09:39:31 AM »
I found an aftermarket replacement at corvette parts worldwide which looks OK (it must be silver) for $400.00 which seems a lot.
The cheapest freight is $138, which is the killer.
Offline StephenSLR
« Reply #8 on: December 31, 2016, 12:18:48 PM »
If it's a genuine HQss wheel it would be worth quite a bit . (sell it n buy an original vette wheel or after market replica ) much easier
I agree, buy a wheel that looks like it belongs there, it'll make the car look that much classier.
s
