Author Topic: Conversion to 4 speed auto  (Read 22506 times)
Offline Darylle
« on: October 01, 2016, 05:33:19 PM »
Hi everyone
Newbie here,I recently purchased a '78 pace car and am interested in going 4 speed auto and was wondering if any recent info is available regarding this conversion. Ideally I am looking for a supplier and or a company that can supply and fit in Sydney area.
Thanks in advance.
Re: Conversion to 4 speed auto
« Reply #1 on: October 02, 2016, 11:01:03 AM »
You will need a cable kick down box out of a VN VP .
« Reply #2 on: October 02, 2016, 02:53:08 PM »
Did my 78 a few years ago have a few pics if you want to email me. Is a very easy conversion all the T350 pipes , torque convertor , tailshaft yolk, flywheel cover fit.You can buy a shifter kit for console includes the gear shift sector all bolts up to the original shifter. The tounge on X-member has to be shortened about 30mm, tailshaft about 50mm,depending on how exhaust has been done may have to redo engine pipe on RHside as rear corner of pan is farther back it may hit on exhaust pipe before it goes thru the x- member
Offline Darylle
« Reply #3 on: October 02, 2016, 11:11:44 PM »
Thank you for the replies, I really appreciate the info prior to jumping in. The exhaust is to be replaced so no issue there, all I need now is a reliable supplier.
I thought the converter had to be changed to "lock up" type or is that an option?
« Reply #4 on: October 05, 2016, 08:08:59 PM »
The lockup function on the T 700 is electronic. Normally controlled by the ECU but can either not be used or manually switched to get the economy.
« Reply #5 on: October 05, 2016, 09:33:44 PM »
Here is an article you need to read , it will give you something to think about.
 http://www.hotrodhandbooks.com.au/eBooks/TPI/TPI%20On%20Line-11-5.html
This one may take a moment to load
http://www.rowand.net/Shop/Tech/LockupTCCWiring.htm
Offline Darylle
« Reply #6 on: October 06, 2016, 09:21:24 PM »
WOW!!
Information overload, not really I knew I joined the right forum.
Thanks heaps people.
