Author Topic: 700r  (Read 16216 times)
Offline james t
700r
« on: July 11, 2016, 03:42:33 PM »
Has any one out there fitted or no of any one that has fitted a
turbo 700r tci manual valve body, do you keep the tv cable i have sent twwo email to TCI with no reply. some one must know. :grr:
Re: 700r
« Reply #1 on: July 12, 2016, 08:52:59 AM »
After googling your question from last post it is essential for TVR cable to be connected & adjusted correctly or it will burn out gearbox. If a holley carb is used an adaptor for cable is required what have you done different to the factory set up? Obviously worked fine for years before you bought the car!
