Author Topic: turbo 700r manual valve body  (Read 17259 times)
Offline james t
« on: July 01, 2016, 06:58:48 PM »
hi all     i have a 82 vet 700r auto i want to change to a manual valve body , but no one can give me full info on what to do.   or which one to buy       . one i looked at says u have to still use the cable ?   they range 500-600 but which one .
Re: turbo 700r manual valve body
« Reply #1 on: July 01, 2016, 10:10:07 PM »
If your looking got true manual shift look at TCI
« Reply #2 on: July 02, 2016, 08:38:42 AM »
Why do you want a manual valve body ? I think from memory the corvette t700 box had stronger parts inside. VN -VP  commodore box is used to retro fit earlier models with t700. Any good auto trans shop should be able to point you in the right direction
Offline james t
« Reply #3 on: July 02, 2016, 08:48:36 AM »
Hi    i had no third gear so i have spent $1000 bucks getting a make over , only to drive it and burn out the third gear clutch again. so now i have brought a TCI 376010 Valve Body,  but still no one cant tell me if i have to use the tv cable with the new part. new to vetts  any help  thanks.  as i am about to give up.  i sold my xy gt replica and my 64 mustang to get this junk heep.  It now owes me more than its worth.
« Reply #4 on: July 02, 2016, 05:28:40 PM »
From memory you have to use the kick down cable & has to be adjusted correctly if you run a Holley carby there is an adaptor for cable connection  to carby. TCI transmissions should be able to answer the question if they supplied the valve body
