Author Topic: Turbo 700 auto box  (Read 17287 times)
Turbo 700 auto box
« on: February 21, 2016, 07:19:08 PM »
Putting this up for a guy I know
Turbo 700 auto cable kickdown was recoed to go in a 78 pace car & never installed asking $1200 contact Chris Shead 0419 790 899
Re: Turbo 700 auto box
« Reply #1 on: February 22, 2016, 12:49:41 PM »
Sir. Being not a gearbox person, could you give a little info on how this differs from the std 350 gearbox as fitted  to a 78.
« Reply #2 on: February 22, 2016, 12:58:35 PM »
mmmm not a box person arrrrr.
the 700 is a 4 speed overdrive box , I don't know if they have a lock up clutch like the 4L60E.
« Reply #3 on: February 22, 2016, 01:39:34 PM »
So on that info it would be a more economical box, smoother changes, but not as eco as the C4 box.
« Reply #4 on: February 22, 2016, 07:36:40 PM »
I have one in my 78 is 4 speed auto 0.7 overdrive & has electric lockup. Comes out of a VN - VP commodore from memory
« Reply #5 on: February 22, 2016, 08:12:27 PM »
Thanks Sirfixalot. The obviouse next question is - is it an easy direct dropin replacement ?....
« Reply #6 on: February 22, 2016, 08:53:12 PM »
Every thing is a drop in fit with some caveats
« Reply #7 on: February 23, 2016, 06:27:23 AM »
Tail shaft shortened about 50mm,  the tounge on crossmember shortened about same amount, maybee modify R/hand exhaust as pan area is longer in gearbox depends how pipe is bent, bit of fancy wiring, a shifter conversion kit ex us for console plate
« Reply #8 on: February 23, 2016, 12:10:09 PM »
Thank you guys, that has answered what I wanted to know.
Offline Ausrs
« Reply #9 on: February 23, 2016, 05:35:38 PM »
the C4 already has a turbo 700 gearbox,4 speed auto and torque converter lock up :)
« Reply #10 on: February 23, 2016, 06:20:36 PM »
they were taking about fitting to a 78 vette
« Reply #11 on: February 23, 2016, 07:33:08 PM »
Yes Sirfixalot has one for sale, I have a 78 and wanted to know what was involved, I also have 87, and the box in it is great, makes for economical cruising.
« Reply #12 on: February 23, 2016, 07:53:21 PM »
Best job I ever did on the 78 2000rpm @ 100kph. 1st gear is lower than t350 & top gear is O/d happy days
« Reply #13 on: February 23, 2016, 10:38:51 PM »
Buy the box, mate it will make for a good project
