Author Topic: Horn wiring and accesories position  (Read 17928 times)
Offline 76Vett
  • From the Shire
« on: October 27, 2014, 02:40:04 PM »
I have a few more questions for the brains trust :huh:
1) I have an open circuit in the horn wiring from the top of the steering column to the relay - the black wire. Does it go through the  Harmonica connector on the column or any other connector?
2) I cannot turn the ignition key anti-clockwise into the accesories position, is it the barrel or is there an adjustment?
3) When I push the emergency flasher button (on the column) it will not lock in, however the flashers do work. Is this part of the indicator switch mechanisim or a seperate switch, any clues on a fix would be appreciated.
Thanks, Allen.  :tears:
The answer really is 42
Offline anychevy
  • Car: 66 convertible
Re: Horn wiring and accesories position
« Reply #1 on: October 27, 2014, 03:59:27 PM »
Yes, from the column, through the harmonica and the bulkhead, to the relay.
Possibly and adjustment at the switch, mounted at the base of the column, operated by a rod from the barrel.
It's a part of the same switch
Offline RHD.68.l89
    • www.invisiblecarbras.com.au
« Reply #2 on: October 27, 2014, 04:22:13 PM »
The hazards are supposed to lock in but cancel when the steering wheel is turned. rotate the wheel and see if the switch was on the "cancel" part of the cam preventing the lock in.
« Reply #3 on: October 27, 2014, 04:33:27 PM »
any more info on when your getting the short  in the horn wiring.
is it when the door is open and key in the ignition.
My emergency  light   switch stays in and  needs to be manually pulled out.
with the acc position  try pushing the Key (mechanism ) in,  then turn anticlockwise
« Reply #4 on: October 28, 2014, 09:48:39 AM »
Yes Bfit these are like the old holdens - push in then turn anticlockwise.
« Reply #5 on: October 28, 2014, 09:52:51 AM »
The emergency flashers should not be disengeged by the cam or anything else in the collmn, they should require you to pull the switch out manually to disengege them. This allows you to drive slowly in the breakdown lane with the blinkers on.
Offline RHD.68.l89
« Reply #6 on: October 28, 2014, 11:14:23 AM »
Maybe on later vehicles but 68 has cancelling if you turn the wheel.
