Author Topic: Correct C3 Engine Block Stamping  (Read 20249 times)
« on: July 08, 2013, 06:59:37 PM »
Lads your assistance please.
I have to re-stamp my block as when we decked it it removed all existing numbers.  The  block had been re-stamped once before (refer to attached pic)
Questions:
The Engine had two stamps as a Engine No: "19S704264" I would call about 3/16 in size and another number "V1004HW" 1/4" in size is this correct ?
If so, What size stamps to I use ?
Does anyone have the correct stamps I can borrow ?
Jethro
Offline anychevy
  • Car: 66 convertible
Re: Correct C3 Engine Block Stamping
« Reply #1 on: July 08, 2013, 07:45:23 PM »
You can buy an alpha numerical stamp set from any machinery or tool shop, but if you want it to look "correct" you really need a "gang holder" and the right size and font stamps, which are not available here, as far as I know.
A poorly stamped engine (done individually) not only looks bad, but can can also hurt the value of your car.
I would put a lot of research into doing this if you want it to remain "matching numbers"
The larger "Flint" engine plant stamp and the lighter partial VIN look typical and the pad has good broach marks, but the heavier partial VIN stamp looks all wrong to me.
JMHO
http://chevellestuff.net/qd/engine_stamp_numbers.htm
« Reply #2 on: July 08, 2013, 07:59:04 PM »
Pryor
Supply letter and number stamps with multiply stamp holder
In imperial. &  metric stamps
It's not to hard to do an excellent Job, one stamp at a time
It takes practise and you only get one go at getting it rite .
Most engineering shops will have several sizes of stamps
Every engine shop I worked at and know of would be able to do this for you.
Once the heads go on it gets very hard.
Different size stamps is the normal
Looking at the photo neither of the two vette model numbers was done with a stamp set.
« Reply #3 on: July 09, 2013, 04:32:52 PM »
Sorted...
Thanks boys  :banana:  got some stamps and it's now stamped good to go..... cheers Geoff
« Reply #4 on: July 09, 2013, 04:56:26 PM »
Jethro I don't mean to be picky
But is that as straight as you could get it
Now that you have it stamped
Ring Brookes engraving in the Goog and get them to engrave a engine ID plate. and drill and tap the block and screw it on over the stamping
or  glue it on
It will look great and add more bling  to your engine bay
« Reply #5 on: July 09, 2013, 05:01:09 PM »
My mate did it   :banghead: I'm so fooken over this build seriously :tears: :tears: Note photo was taken this arvo and no Fooken Heads as yet  :tears: :tears: supposed to be going to the dnyo this Friday at Orange
« Reply #6 on: July 09, 2013, 05:41:51 PM »
I have heard some marathon head  job story's
But this one takes the cake
« Reply #7 on: July 09, 2013, 05:57:16 PM »
:zip:
« Reply #8 on: July 09, 2013, 06:34:21 PM »
:zip:
First time for everything CammO
« Reply #9 on: July 14, 2013, 07:37:27 PM »
I reckon looks like  a 1969 stamping
Offline anychevy
« Reply #10 on: July 14, 2013, 08:27:22 PM »
« Reply #11 on: July 14, 2013, 08:38:21 PM »
Dave seriously back then every bastard was off off thier :rol: dial
