Technical Tips
Electrical-Electronics-Air-Lighting-Guages-Security-Vacuum
Window washer not working
Topic: Window washer not working (Read 10747 times)
72C3
Two Barrel
January 30, 2013, 08:56:03 PM »
Found a new window wash tank to replace the original that was split. Gave it a test run and nothing. It seems the pump is not pumping. Anyone with experience with washer motor problems out there. Doesn't seem to run at all.
Stu
anychevy
Four Barrel
Car: 66 convertible
Re: Window washer not working
January 31, 2013, 02:31:38 PM »
Quote from: 72C3 on January 30, 2013, 08:56:03 PM
They're fairly simple, with a 12v+ IGN supply from the wiper motor and a ground (-) when you press the wash button.
It has a solenoid that activates a cam on the wiper motor that drives the pump
Test it first, but if it doesn't even "click" It's probably shot
http://www.ecklerscorvette.com/corvette-windshield-washer-pump-with-3-ports-1968-1974.html
gtc
Car: 1970 454 Manual
January 31, 2013, 10:41:53 PM »
I gather they were pretty unreliable. The previous owner of my C3 fitted a tank with washer motor on it, possibly from a Holden, and left the broken unit on the back of the wiper motor for completeness.
72vet
Reply #3 on:
February 01, 2013, 05:21:38 AM »
Hi Stu, is there power from the wiper switch to the washer motor?
Have you purchase an aftermarket washer bottle with motor “all one unit” or, is the pump running off the wiper motor as Dave has mentioned?
CLICK ME
to see my albums.
Technical Tips
