Author Topic: steering question  (Read 12203 times)
steering question
« on: August 14, 2012, 06:15:16 PM »
hi guys,i just replaced my idler arm on my 71,now the car pulls to the left?is this normal until the part wears in?the old one had play due to worn bushs,the new one is tight as,any tips?:ado:
Offline anychevy
  • Car: 66 convertible
steering question
« Reply #1 on: August 14, 2012, 07:57:15 PM »
Quote from: MADLT1 link=topic=9338.msg1045943445#msg1045943445
hi guys,i just replaced my idler arm on my 71,now the car pulls to the left? is this normal until the part wears in?
No !
Check the dimensions are the same as the old one.
If it's correct, you need a wheel alignment.
Offline craigh
steering question
« Reply #2 on: August 14, 2012, 08:34:20 PM »
Replaced mine as part of the suspension work and did not encounter anything like that.
With larger wheels/Tires the wander can be dialed out with caster adjustments (More rear vs front Shims).
Offline craigh
steering question
« Reply #3 on: August 14, 2012, 08:35:07 PM »
Quote from: craigh link=topic=9338.msg1045943447#msg1045943447
may be alignment but what was it like before.
steering question
« Reply #4 on: August 14, 2012, 09:45:39 PM »
Do  you power steering
steering question
« Reply #5 on: August 15, 2012, 08:09:46 AM »
If car has original ram power steering it probably needs the valve readjusted to nuetral/centre position
steering question
« Reply #6 on: August 15, 2012, 10:22:35 AM »
Quote from: sirfixalot link=topic=9338.msg1045943451#msg1045943451
:agree:
This link may help http://willcoxcorvette.com/repairandinstallhelp.php?hID=188
steering question
« Reply #7 on: August 16, 2012, 08:20:50 AM »
If RHD, the pitman arm and idler arm should be at the same height.  My 77 had a dodgy conversion where they bolted the idler arm 2 inches higher than it should have been!
steering question
« Reply #8 on: August 16, 2012, 04:02:21 PM »
thanks for all the input guys,i took the vet for a drive today and did a lot of turning with it and it has free.d up.strange but it steers straight now,must have needed freeing up,cheers
