Author Topic: 1985 Diff seal  (Read 14433 times)
1985 Diff seal
« on: May 25, 2012, 10:20:51 AM »
Mine is leaking a little. Do these diff's have a gasket for the rear of the pumpkin or do they just use gasket goo?  I tightened the rear housing bolts and it still leaks.  :tear:
Can't seem to fing any replacement gaskets so I assume we just you the gasket goo?
:beer:
1985 Diff seal
« Reply #1 on: May 25, 2012, 11:18:02 AM »
77
if you have to remove the rear
it would be  the time to add a drain to the housing
For your oil  servicing.
makes servicing  a lot easier.
I use Limsip 90 in my car
stops the thing chattering in corners
Bfot
1985 Diff seal
« Reply #2 on: May 25, 2012, 12:00:39 PM »
Indeed!  Just like when you remove the auto pan for servicing!
:beer:
1985 Diff seal
« Reply #3 on: May 25, 2012, 03:00:14 PM »
Well Yes but not quite
At least you change the filter in the auto  when its pants come off.
1985 Diff seal
« Reply #4 on: May 26, 2012, 09:10:03 AM »
With a drain plug I don't get a panful of trans fluid on my head!  I can never seem to drain a pan that has no plug without doing that! :eek:
1985 Diff seal
« Reply #5 on: May 26, 2012, 11:10:35 AM »
Lol
True
1985 Diff seal
« Reply #6 on: May 27, 2012, 10:21:17 AM »
Quote from: Bfit link=topic=9235.msg1045942869#msg1045942869
Bfot
Did the same thing to me Munchie when I had it out
1985 Diff seal
« Reply #7 on: June 08, 2012, 11:49:16 AM »
Quote from: 77CVT link=topic=9235.msg1045942868#msg1045942868
Good quality sealer
Be careful doing that.
The bolts are " self tappers" installed at the factory; very easy to lean on them a little hard and strip the thread out.
When I built my D44, I installed and Loctited studs into the case so I wasn't working the threads in the soft alum housing
