Author Topic: Any ideas for brake upgrade early C4 84-86  (Read 16010 times)
Offline 86 iron
« on: September 14, 2011, 06:58:12 PM »
Who has upgraded their brakes what components
did you use,and was it worth it.
« Reply #1 on: September 25, 2011, 07:06:31 PM »
Upgrade to the late 13" rotor J55 brakes (need custom adapter fr early cars  )
http://www.coppercorvette.com/c4togsbrakes.htm
Most popular in USA now are the C5 calipers ( cheaper ) but they won't fit stock 16 and sawblade 17" rims
http://forums.corvetteforum.com/c4-tech-performance/1782167-c5-brake-conversion-for-85-a.html
Local made conversion for sale on eBay now
http://www.ebay.com.au/itm/CHEV-CORVETTE-C4-PBR-BIG-BRAKE-UPGRADE-KIT-84-87-/230677199553?pt=AU_Car_Parts_Accessories&hash=item35b56ebac1
Offline 86 iron
« Reply #2 on: September 28, 2011, 05:34:46 PM »
Do you think the C5 brakes are better than the j55.
are the pbr same as j55,thanks for the links:beer:
« Reply #3 on: October 02, 2011, 12:26:04 AM »
Quote from: 86 iron link=topic=8765.msg1045941093#msg1045941093
Apparently so.
The C5 rotor is much thicker  meaning you can brake harder longer because less heat build up and less brake fade.
In saying that, the J55 were a big improvement over the stock brakes on my '87
C5 calipers are differnt to J55 ones but PBR makes all the Vette calipers; stock , J55 and C5
Offline 86 iron
« Reply #4 on: October 19, 2011, 05:15:46 PM »
What booster fits is a steel one available,i heard some local models are interchangeable but not sure which one:thumb:
Re: Any ideas for brake upgrade early C4 84-86
« Reply #5 on: October 18, 2012, 12:15:58 AM »
C4 ZR1's use a steel booster if I recall correctly.  So if you have no luck sourcing alternatives try one of those.
