Technical Tips
Post 84
What local parts fit C4s
Topic: What local parts fit C4s (Read 12635 times)
86 iron
Two Barrel
July 16, 2011, 09:57:06 AM »
Hi everyone,
im trying to get a list together of local parts that fit C4s ie commodore &falcon parts that are a direct fit for our C4s.
i have heard stories of parts fitting but not sure which ones,
any knowledge you have would be great:cheers:
87Z51
Four Barrel
July 17, 2011, 11:37:18 AM »
Almost nothing
Engine is a normal SBC so no shortage of internal engine or perf parts.
TPI is a unique setup that was never available in any Oz model.
Some Commodore sensors fit later ('90+ ) C4's that had MAP system
T700 auto trans is same as fitted to VN /VP Commodores
Universal joints are std Spicer 1310 and 1350 series available anywhere.
86 iron
Two Barrel
July 17, 2011, 04:16:51 PM »
How about stuff like calipers, brake pads ,booster.
the early C4s must be the worst 84 to 87.:shake:
86 iron
Two Barrel
Reply #3 on:
September 03, 2011, 12:09:06 PM »
Does anyone sell new wheels with correct offset:huh:
77CVT
Fuel Injected
Reply #4 on:
September 05, 2011, 03:24:53 PM »
Doubt it on the wheels. Def not for C3's.
Can use over the counter oxygen sensors.
MADVET
Tri Powered
Reply #5 on:
September 05, 2011, 06:39:01 PM »
There really isn't a need to try and fit falcadore parts to your C4 as the right parts are really not that expensive. Many of the parts are very similar in price to a commodore or marginally dearer so it's not really worth the effort.
If you're after wheels for your early C4 then the new C6 Vette is your savior. Specifically the wide bodied C6's ie: Z06, GS and the ZR1. Any wheels that are made to fit the front of these Vettes have an offset of 40mm and will fit your early C4 perfectly.
NOW WE'RE TORQUING!
Technical Tips
Post 84
