Author Topic: Video: Scandinavian homemade dyno is dangerously awesome  (Read 5821 times)
« on: May 28, 2011, 06:39:57 PM »
Tuning an engine can be a delicate procedure. There is a lot of time and patience required to dial things in just right. You can spend hours and big dollars adjusting parameters on an expensive professional dynamometer –or you can be a crafty Scandinavian and homebrew a dyno right in your yard.
Apparently, all it takes is the rear end from a heavy-duty truck, some straps and a quick skaal to Odin. The result is a snowed-in dyno that can tune all the V8-engine-swapped drift machines in the neighborhood.
Watch ingenuity at work. :thud:
[youtube]fwPuzEhB1LI[/youtube]
