Technical Tips
Electrical-Electronics-Air-Lighting-Guages-Security-Vacuum
sticking window
Topic: sticking window (Read 12250 times)
billsteamshovel
Newbie
sticking window
May 14, 2011, 07:00:02 AM »
I was playing around with my 85 Coupe yesterday and was giving the windows a good scrub and the drivers window now only goes up halfway?
Any idea's before I pull it apart.
It was working perfectly.Its RHD so its the drivers door,when it stops halfway it just clicks?
Any help welcome.
Regards Billy
sirfixalot
Fuel Injected
sticking window
May 14, 2011, 07:19:18 PM »
Have a look on zip corvette site they have a tech article the part no is ZDR-394 & there is a link to install instruction
billsteamshovel
Newbie
sticking window
May 19, 2011, 02:45:34 PM »
Thanks for that mate,much appreciated,I just googled seatbelts and your name came up,are mine legal in NSW or do they need changing for the blueslip.
Regards Billy
billsteamshovel
Newbie
sticking window
Reply #3 on:
May 19, 2011, 02:56:12 PM »
Found the article at Zip Corvette sirfixalot and will order the part directly,thanks mate.
Kind Regards Billy:ado:
sirfixalot
Fuel Injected
sticking window
Reply #4 on:
May 19, 2011, 08:23:17 PM »
Unfortunately belts do have to be replaced. I havent done a c4 coupe, I have done a convertible but shoudnt be a problem.
billsteamshovel
Newbie
sticking window
Reply #5 on:
May 23, 2011, 03:22:18 PM »
Thank you.
Billy
th693
Two Barrel
sticking window
Reply #6 on:
May 26, 2011, 07:02:14 PM »
sounds like your window regulator is wearing out, you could try lubricating the window channels with silicone spray to help the window slide up with less resistance, thus less work on regulator.
billsteamshovel
Newbie
sticking window
Reply #7 on:
May 26, 2011, 07:47:03 PM »
Thank you,will try that,it has had a lot sanding dust from repairs i did on the bonnet,maybe its clogged up will give it a go though.Cheers
Billy
Technical Tips
sticking window
