Author Topic: In line P/S cooler fitted.  (Read 13130 times)
« on: November 07, 2003, 08:59:26 PM »
Thought some might be interested in seeing the in line power steering cooler I've just fitted. I had originally intended fitting it as an auxillary trans cooler, but opted for it's present configuration after having the side mount extractors modified which placed them fairly close to the steering box. I bent up some 3/8" stainless steel tubing for the fluid lines (polishing them first of course :b2) as well as making some alloy mounts for the cooler itself.
Offline david_moore
« Reply #1 on: November 09, 2003, 08:02:53 PM »
Nice work Brutus!! The steering box on my old '79 would leak in very hot conditions, after fitting a steering cooler that stopped! I must bring my books on building strokers over! hint hint. I am also keen to see Scott81's DVD if only for the sound track!!!!!:drink:drink:22:22:drink:drink
« Reply #2 on: November 10, 2003, 07:40:05 AM »
I've been scouring the net for everything I can find on stroker motors so anything you have would be appreciated Dave. All I need to find now is a cam to suit and I'll start building it.  All expectations indicate 430+ lbs/ft of torque! I'm not too worried about HP figures cause it's torque that walks!
Btw, I picked up a T 700 R4 trans on Friday. It's a fully rebuilt pre electronic model with Kevlar bands, Corvette servos, manualised valve body, etc and supposedly built to handle 600hp for $1500.00!. It had a 4000 stall convertor which ain't too good for the street so I'm on the lookout for a decent one to suit a slightly milder application. Probably around 2600.
Bob
Offline david_moore
« Reply #3 on: November 10, 2003, 06:31:48 PM »
Sounds like an absolute bargain for the gearbox you got. Choosing a camshaft is one of the real fun things when building an engine. Have you seen Ryan's Engine Combinations? It is a good site, don't be put off by the bible stuff! It appears Christians can be rev heads too!!;ay
I reckon it is a pretty good site and I don't fear God!!
Check it out
http://ryanscarpage.50megs.com/index.html
« Reply #4 on: November 10, 2003, 08:20:45 PM »
I've seen Ryan's page with all those engine combos and it really makes you want them all.:b2 Now you've made me go back there and droll all over them again. Thanks heaps. One thing I still have to work out with this 383 is whether I need a cam with a small base cirlce or not. I'll have to check the rod bolts to see if they've been clearanced or not. Fortunately there's no ruch with this project. Gonna check out C.O.M.E.'s web page for a cam selection data sheet.
Offline Scott81
    • http://www.c3sharktank.com/
« Reply #5 on: November 12, 2003, 01:11:10 PM »
Is this the end of the world?  Has time stopped?  Can pigs fly?  Do I see dirty spots on that motor?  Do I see non-shiny chipped paint on that waterpump?  Tell me I'm wrong....   ;35
« Reply #6 on: November 12, 2003, 01:13:18 PM »
Purdy!
« Reply #7 on: November 12, 2003, 07:52:40 PM »
Soon to be replaced with a polished Edelbrock water pump.......as if you didn't already know Jitterbug.:22
I actually chipped that paint on purpose just to give you somethng to laugh about.:b2
