Technical Tips
Post 84
Noisy C4 power steering pump
Topic: Noisy C4 power steering pump (Read 10490 times)
Thunder Kiss
Four Barrel
February 21, 2011, 07:29:20 PM »
The power steering pump in my '86 has recently become very noisy (high pitch whine, increases with rpm). I've checked the fluid level and it's OK.
Anyone know if it's interchangeable with a local pump? Can it be rebuilt here by someone like Pedders or am I better off ordering a rebuilt unit from the US for $100-$150?
Shane Finn
Four Barrel
February 21, 2011, 09:16:37 PM »
If the fluid is more than a year or so old, I'd replace it first and see.
I had the same thing in my C5 when it got hot. Replacing the fluid cured the problem. Apparently the fluid will absorb a lot of moisture and eventually will cause the problems you describe.
Of course you might just have a shot pump as well...
2001 Z06, Torch Red
87droptop
Four Barrel
Mood: Always good !!
February 21, 2011, 09:31:16 PM »
my 87 leaked lots of fluid when i was replacing the water pump, sent it in 2 a friend in Para, he then sent it 2 a local pump rebuild place, and now it is as good as new.... i dont think yours would have any issues rebuilding.
Thunder Kiss
Four Barrel
Reply #3 on:
February 24, 2011, 03:57:34 PM »
Thanks guys, I've forked out US$30 for a "no noises when removed" used pump. We'll see how it goes, otherwise I'll send my existing pump off to be rebuilt locally.
Technical Tips
Post 84
