Author Topic: Project C5X: Cam, Head, Manifold and Throttle Body Install Video Part 3  (Read 6583 times)
Thw work continues the LS1 disassembly including the removal of the front air dam, radiator, radiator fans and wiring harness, lifters, balancer, front cover, timing chain and gears. Also, the rack and pinion is removed from the car to expedite the camshaft swap. Then the new Comp Cams C4orce camshaft, adjustable timing chain and gears and new crank and oil pump drive gears are installed.
<script src="http://player.automotive.com/player.js?embedCode=pxMG0zMTqfMClY-Rwi7OyLD-2PCsdCyI&adSetCode=M2ZjI6Ai1fUldBemTb3GaivmPo_A2CNe&deepLinkEmbedCode=pxMG0zMTqfMClY-Rwi7OyLD-2PCsdCyI"></script>
