Author Topic: 71 rebuild  (Read 903600 times)
71 rebuild
« Reply #60 on: November 15, 2010, 03:05:08 PM »
Quote from: Jethro link=topic=7864.msg1045938306#msg1045938306
Quote from: wabco40 link=topic=7864.msg1045938300#msg1045938300
I have relocated the park brake bracket to the top of the trailing arms. I have also fitted a 1/2" (per side) shorter rear spring. With this set up I've got about 1/4" clearance between the end of the spring and rim and about the same clearance between the tyre and the front area of the frame kick up.
ket.com/albums/ff391/wabco40/IMG_3805.jpg[/IMG]
Hey Wabco, no replacement for perfection and I reckon you've got that looks a treat, buddy:luv::luv::luv::luv::luv:
Thanks Jethro,
Things are starting to come together now.
71 rebuild
« Reply #61 on: January 24, 2011, 11:25:35 AM »
I have not managed to do much to the car in the last month or so due to work commitments.
However did manage to paint the side grills and rocker covers.
The raised edges where masked and then sprayed with primer and base colour. The masking was removed and the whole lot sprayed with a suitable clearcoat.
I wasn't sure how this would work however they look quite good. I would hate to do them again as the masking is a real pain.
71 rebuild
« Reply #62 on: January 24, 2011, 11:56:18 AM »
sh#t mate! They turned out awesome!
71 rebuild
« Reply #63 on: January 25, 2011, 06:17:58 AM »
Steady hand on that tape work, looks smick:ado:
71 rebuild
« Reply #64 on: January 25, 2011, 11:28:58 PM »
Just be a bit careful with that tyre/spring bolt clearance! Years ago I had a blowout coming out of a driveway because of the tyre flex from side to side the bolt hit the tyre! I think I had more than 1\4in room?
71 rebuild
« Reply #65 on: January 26, 2011, 08:23:55 AM »
Quote from: 69 DIRTY RAT link=topic=7864.msg1045938765#msg1045938765
Thanks Dirty Rat. What size rim and tyre are you using?
I am still considering different rear suspension options. I was looking at Speed Direct rear coilover kit but I am not sure how proven this product is. I have asked the question on US forums but had very little come back about it.
Brad.
71 rebuild
« Reply #66 on: January 31, 2011, 08:53:32 PM »
I have 18in rims now but when it happened I had 15in 255/60s. If you have room to shorten that bolt then that maybe a solution?
71 rebuild
« Reply #67 on: February 26, 2011, 04:13:24 PM »
I had my front grills chromed at a small shop in Bangkok. They did a reasonable job and as expected it was impossible for them to polish inside the squares.
The outer edges of the squares and the bottom and side edges came out good.
I plan on painting the inside of the squares and the inside bottom section as per factory. However I am unsure if I will paint them standard grey or body colour.
71 rebuild
« Reply #68 on: March 23, 2011, 10:00:02 PM »
I have removed the engine to do some more work on it. Previously I turned the stub on the harmonic balancer down 6mm to retain pulley alignment when I fitted the crank trigger wheel. By doing this I also take a small amount on material off the counterweight to clear the timing cover.
I had decided to strip the engine down and have the rotating assembly re-balanced.
Also painted the block blue (chevy orange didn't match the colour of the car) and had Hogan's racing manifolds custom make a new EFI manifold for me.
The manifold is 8" from the chinawall to its highest point. This is about 1" less then the previous set-up I had. This will give me plenty of hood clearance even with the throttle body fitted.
Offline 87droptop
  • Mood: Always good !!
71 rebuild
« Reply #69 on: March 24, 2011, 06:20:42 AM »
thats an awsome job mate, well done
71 rebuild
« Reply #70 on: March 24, 2011, 07:35:27 PM »
ORSUM looking motor buddy !
71 rebuild
« Reply #71 on: June 15, 2011, 09:42:54 AM »
Slow going on the assembly at the moment. Have had no time due to work.
I have the engine back in and have started to install the head light units. I had forgotten how cluttered the engine bay gets with all the head light and wiper door vacuum hoses!!!
I was hoping to have it finished by now however it looks like it will be closer to the end of the year.
71 rebuild
« Reply #72 on: June 15, 2011, 11:45:34 AM »
nice :drag:
71 rebuild
« Reply #73 on: June 15, 2011, 02:05:07 PM »
Mate
I have just read most of your post here
looks like a top effort
I hope to see it in person one day
71 rebuild
« Reply #74 on: June 15, 2011, 05:13:09 PM »
Quote from: wabco40 link=topic=7864.msg1045940215#msg1045940215
[IMG=700x525]http://i1233.photobucket.com/albums/ff391/wabco40/IMG_4093.jpg[/IMG]
[IMG=700x525]http://i1233.photobucket.com/albums/ff391/wabco40/IMG_4100.jpg[/IMG]
OOLLEY DOOLEY :drool:
Remind me not to line you up at a set of traffic lights :drag:
71 rebuild
« Reply #75 on: June 15, 2011, 08:16:26 PM »
Quote from: Bfit link=topic=7864.msg1045940224#msg1045940224
Mate
Thanks Bfit. I wish I had more time to work on it.
71 rebuild
« Reply #76 on: June 15, 2011, 08:27:43 PM »
I have installed the radiator since the last pictures where taken and have fired the engine up.
Have been playing around with tune in the ECU and very pleased with the results.
I have also flashed the ECU with FAST latest software upgrade, this has self learning for the VE table however will not have a chance to try this until I can drive the car.
71 rebuild
« Reply #77 on: June 15, 2011, 09:16:45 PM »
Hey Wabco, email me your favorite pic of your car and I'll set it up as your avatar, if you want.
71 rebuild
« Reply #78 on: June 16, 2011, 07:30:55 AM »
Quote from: Admin link=topic=7864.msg1045940231#msg1045940231
Ok, thanks.
71 rebuild
« Reply #79 on: June 16, 2011, 11:01:06 AM »
There you go. :hi:
