Author Topic: The clock  (Read 9152 times)
Offline pud
The clock
« on: October 05, 2010, 03:55:22 PM »
Hi......Ive looked every where but cant find out the easiest way to remove the clock from a 64 vette.  I really dont want to pull the whole dashboard out because, I probably would balls it up putting it back.
tah:beer:
The clock
« Reply #1 on: October 05, 2010, 04:53:22 PM »
From the Mid America Motorworks website:
Tech Tip: Some customers have called us asking "How do I remove my 1963-1967 Corvette Clock  from the dash in order to restore it?" It's simple, if you know the trick! Midyear clocks are held in place with two "grasshopper" clips on the inside of the dash. First, remove your center dash lower vent side panels. This will allow access to the rear of the clock. On the back of the clock, you will feel the two v-shaped, "grasshopper" clips. Press down on the open end of the clips and slide them off of the clock ball-studs and the clock may be pulled out of the face of the dash. Re-installation is just the reverse.​
The clock
« Reply #2 on: October 05, 2010, 05:22:18 PM »
Quote from: gtc link=topic=7840.msg1045937920#msg1045937920
Is their anything gtc don't know????
The clock
« Reply #3 on: October 05, 2010, 05:41:26 PM »
Quote from: Jethro link=topic=7840.msg1045937921#msg1045937921
The 2010 Melbourne Cup winner ... not yet anyway. :wink:
Offline pud
The clock
« Reply #4 on: October 06, 2010, 09:19:08 AM »
Thank you very much for that.  I'll give it a go and see what happens.  :ado:
pud
