Author Topic: Manula to Auto questions  (Read 17881 times)
« on: September 24, 2010, 11:37:30 AM »
Car = 1970
I've read a few of the posts in this section and I see people reccomend the TH400 and TH700 boxes for a conversion, but I have a few extra questions I did not notice the answers to.
Does going from a muncie to a auto require any crossmember changes? Are there any high performance auto's that are a direct replacement without crossmember changes or driveshaft alterations?
Does it require that the shift console be replaced to an auto as I was thinking of using the manual shift console and leather shift boot even though it was auto but I'm not sure if it would allow full movement. I plan on having an auto thats got a full manual shift kit.
Does the hole in the floor and everything else line up for the shifter?
What else do I need to consider?
« Reply #1 on: September 24, 2010, 04:24:28 PM »
Have a look at tciauto.com  site  technical resources should answer a lot of questions has dimensions for different boxes & gear to strenghten box.
Auto shifters usually mount to floor not gear box so can be positioned wherever required.
Manual corvette chassis  has a fixed crossmember for gearbox. Auto chassis has a removable crossmember.
« Reply #2 on: September 24, 2010, 05:06:51 PM »
Auto's run fluid through the radiator for cooling, so different radiator.
Autos need the kick down set-up installed on the carby.
May need a different tailshaft.
Not sure if the cross member needs modification.  Perhaps check digital corvette or corvette forum.
Will requiring re-wiring so that the car won't start whilst in gear.  I have bypassed this going from auto to manual, but I'm not sure how it works going the other way.
T400 (and T350) are a mechanical (non computer) 3 speed box.  Both are fairly tough, and are stronger than the T700.
A T700 is also referred to as a 4L60 or 4L60E. E = electronic
The T700 is a 4 speed box and was used in commondores and C4 vettes.  VN's used a non-computer controlled version.  Later commodores and C4's used an electronic version.  T700's have a lock-up torque converter which can be tricky to incorporate, depending on who you ask.  I can't remember exactly, but if you don't do it right top gear will burn out or break.  A T700 will require modification to the cross member to make it fit.
A T700 will struggle to last behind a 502 rat :)
I may have researched this subject previously :hammer:
« Reply #3 on: September 24, 2010, 11:22:13 PM »
I was talking to a guy at work about this tonight and he suggested I dog box the Muncie and install a verticle gate. I may have to research what is involved in this and how practicle/streetable/durable it is and compare it to the auto option.
« Reply #4 on: September 25, 2010, 12:33:47 AM »
Quote from: demonx link=topic=7828.msg1045937852#msg1045937852
What's your objective?
Don't like clutches?
« Reply #5 on: September 25, 2010, 01:44:10 AM »
Quote from: gtc link=topic=7828.msg1045937853#msg1045937853
It's been about 15 years since I had a manual - I've become lazy!
So yes. However since I bought my HQ ute which has a powerglide with a manual shift kit, I've become a fan of the setup. I'd just like more gears on the vette for long trips etc.
Offline mick
« Reply #6 on: September 26, 2010, 04:35:20 PM »
Get a Keisler 5 speed, dont get a Auto(IMO).
http://keislerauto.com/
A guy thats coming to a car show i host has put one in his vette, Ill let you know if he is happy with it.
« Reply #7 on: September 26, 2010, 07:05:01 PM »
Quote from: Scott link=topic=7828.msg1045937848#msg1045937848
Stock and aftermarket shifters have provision for the neutral start switch
As simple as having a manual switch to operate the lockup or installing a different switch in trans so it locks up automatically whenever in 4th gear (O/d )
Pre '88 T700's (27 spline input shafts ) only have full flow to the trans cooler when convertor locked.
Running these without lockup can lead to trans overheating.
On later models; running without lockup is no different than running a TH400 where you have a certain % slippage with a non locking convertor
« Reply #8 on: September 26, 2010, 07:22:00 PM »
Quote from: demonx link=topic=7828.msg1045937854#msg1045937854
T700 Pros
Low 1st gear
T700 with 3.08 rear gives equiv of TH400 w/3.73's  (23% more torque )
With 3.5 rear equiv to TH400 w/ 4.11's
With 3.08 rear ,T700 .70 4th (O/d ) gives equiv of TH400 with 2.16 rear; great for cruising economy
Best of both worlds
Cons.
T700 is p#iss weak in stock form. May break if you look at it
Can be built but will cost.
I have had one behind my 410RWHP 383 for 4 years but it cost me $3500 plus core back then
