Author Topic: stud pattern difference c3 and c4  (Read 16616 times)
Offline 87droptop
  • Mood: Always good !!
« on: August 28, 2010, 08:23:15 PM »
Hi all, would anyone know the exact wheels stud measurments for a c3 and a c4( or holden, bmw), i can get these adaptors from the US but i need to know the original size to make fit the holden/bmw/c4 wheels onto the c3.
THANKS...
« Reply #1 on: August 28, 2010, 10:58:18 PM »
This site may help. It lists the PCD (or bolt pattern) for Vettes:
http://www.vehicle-bolt-pattern.com/chevy-lug-reference-guide.html
Offline 87droptop
« Reply #2 on: August 29, 2010, 07:25:09 PM »
thank you
« Reply #3 on: August 31, 2010, 11:54:07 AM »
Problem is going to be wheel offset / backspacing differences; very big on C4 rims ( 6"+ ).
By the time you space the  rim out to clear suspension may be too far outside guard
PM me if you want to borrow a C4 rim to test fit
Offline 87droptop
« Reply #4 on: August 31, 2010, 07:50:09 PM »
thanks mate, i do also have a c4 with 18" wheels, and i was told the offset is very big on that, but my main issue is that i was told that the stud pattern varies, so i was going to get 2" spacers that fit a c3 then the other end will be a c4/holden/bmw pattern, then i have a much greater choice when picking the wheels for the c3. so from what you know, you think c3 and c4 stud patterns are the same?? i can see a very deep dish on the c3 standard wheels, i'm sure not many other wheels will fit, but then by doing this i might have a lot more options. Thanks again.
Offline BlueVette
« Reply #5 on: August 31, 2010, 10:17:33 PM »
FYI, BMW bolt pattern is 120mm and Corvettes have 120.65mm (4.75")
I would NOT bolt 5x120mm pattern wheels without adaptors on a Corvette!:eek:
All 1968s carry the stigma of being "the worse quality" of all Corvettes.
« Reply #6 on: September 01, 2010, 09:59:11 AM »
Quote from: 87droptop link=topic=7802.msg1045937764#msg1045937764
from what you know, you think c3 and c4 stud patterns are the same?? i can see a very deep dish on the c3 standard wheels, i'm sure not many other wheels will fit, but then by doing this i might have a lot more options. .
Stud pattern is the same
From what I am seeing online C3's ( 78 at least ) had 4" backspacing
So a 2" spacer would let you run a 6" backspacing rim
Biggest problem with aftermarket wheels appears to be caliper clearance; not susp clearance
Offline 87droptop
« Reply #7 on: September 01, 2010, 07:33:39 PM »
ok guys, thanks for the info, hopefully all this will work out soon, somehow....
