Author Topic: leaking th350  (Read 9114 times)
Offline DA383
leaking th350
« on: November 27, 2009, 12:22:15 PM »
hi all
 i have oil leaking out of where the kick down cable goes into the gearbox, i have already cleaned both surfaces and silastic it together to seal it but oil still comes out, is there a trick to this? does it need a gasket or o-ring ? any help would be appreciated.
thank you dennis
leaking th350
« Reply #1 on: November 27, 2009, 03:41:39 PM »
From memory it should have an o ring.  I think there were some that had a rubber sleeve type but if your end has a groove in it it will be an o ring type.
:beer:
