Author Topic: cold start injector  (Read 12332 times)
cold start injector
« on: September 12, 2003, 03:13:53 PM »
How feasable would it be to somehow break into the cold start wiring to make a switch you could use at WOT to use the cold start injector for more fuel/power?
Or am I thinking too much again?  ;ay
cold start injector
« Reply #1 on: September 12, 2003, 04:57:57 PM »
You wanna crack 200rwhp pretty bad eh? :22
I think you are thinking too much.  I have heard of people deleting it (with aftermarket intakes) but not of using it to richen up the mixture while under power.
I don't know if it is located well to do what you are thinking of anyway.
Personally, I'd use an adjustable regulator to add more fuel under load and when I managed to get my car to make enough power to max out the stock injectors I'd change them to higher flow units.
