Author Topic: 88 vette electrical connector help  (Read 13307 times)
Offline coradict72
« on: September 17, 2008, 09:11:41 PM »
next to the brake booster or near it
there is a 2 pin electrical connector with  bracket
suppose to mount on firewall with screw.
It has 2 purple wires gong to the connector
and inside that connector is a buff color 5amp
fuse inside.
What does it do? what is this connector called?
I need to replace it
It could the intermittent wiper any help welcome
Offline VET-005
« Reply #1 on: September 18, 2008, 06:57:39 PM »
put a picture up will help identify what it is as with heaps of different conversions in a C4 it could be anything.
Click Images For My Gallery
Offline coradict72
« Reply #2 on: September 18, 2008, 08:32:24 PM »
Thanks for coming back the connector is squashed so pic nbg.
I'll just have to go over the wiring diagram again its the only connector that has a yelo 5amp flat fuse inside.
Saw it at greg morris shop he didnt know what it does but suggested intermittent wipers may be its job, he is very busy might have to pop in see him and trace it and let you know.
2 purple wires passing thru the fuse inside the connector....cheers
« Reply #3 on: September 19, 2008, 11:24:45 AM »
Start it up, pull the fuse and put on the int wipers and other switches to see if it stops working?
