Author Topic: 77 15x6 wheel will it fit 72  (Read 33845 times)
Offline mick
« Reply #20 on: May 19, 2008, 08:50:16 AM »
Just a quick update I got confirmation that a 15x5 1977 wheel will fit my car (1972) I just bought that wheel and will organise rubber that is the same diameter as the wheels on the car, then build tire holder to suit.
Thanks for everyone's input.
:22 ;42
« Reply #21 on: May 19, 2008, 12:48:05 PM »
Where did you buy the (assume you meant) 15x6?
Offline mick
« Reply #22 on: May 19, 2008, 01:08:52 PM »
I actually got 15x5, which was good. Got it from good old ebay as per link above I previously put up.
« Reply #23 on: May 19, 2008, 01:20:36 PM »
the good old u s comes through yet agian:boldgood price too,although the shipping would be a bit pricey maybe?
« Reply #24 on: May 19, 2008, 02:35:07 PM »
Reason I asked is that eBay ad says '88 to '96.
Offline humphbri
« Reply #25 on: May 19, 2008, 02:49:31 PM »
I would double check the wheel before shipping it over here. I know that the 1978 spare was a 15x5; but I didn't think the 77s came with a space saver.
;46
Offline mick
« Reply #26 on: May 19, 2008, 03:24:26 PM »
Offline mick
« Reply #27 on: May 19, 2008, 03:28:36 PM »
;46
The guy promised me it would fit my 72 no worries (i bloody hope so). Mabye its late 77 date stamp for a 78 model.
We will see I guess.
One thing I do know every time ive done business in the USA I have had excellent and honest service, lets hope it continues.
« Reply #28 on: May 20, 2008, 12:55:17 PM »
'77's had a normal spare.
Offline humphbri
« Reply #29 on: May 21, 2008, 09:04:04 AM »
I checked out the e-bay ad; you'll be right with that rim, it is a 78 wheel with a 77 date code and will definately fit your 72. FYI, they weren't originaly painted yellow, they were black with a Goodyear tyre on them.
« Reply #30 on: May 21, 2008, 10:08:20 AM »
another option is to go brand new repo.....
crager make a replica ralley wheel and could proberly make to the width you need and cheaper than a 2nd hand rim....mine had replicas on it and looked a damn sight better with new trims and caps.....
Offline mick
« Reply #31 on: May 28, 2008, 05:37:14 PM »
Hey all,
            Got the wheel. It fits fine.
I want to thank everyone for their input, without this Forum so many jobs would be a nightmare !!!!!
:24
« Reply #32 on: May 28, 2008, 06:14:13 PM »
So now we want a pic of it in it's carriage under ya tank. :22
Offline mick
« Reply #33 on: May 29, 2008, 07:44:33 AM »
that may take a while im currently making a mock up in corflute(cheap plastic) to see how it looks before I even think about it in aluminium.
Offline mick
« Reply #34 on: May 30, 2008, 09:12:24 AM »
I got a 205 tyre that is 4mm less diameter than my 295's, happy with that.
« Reply #35 on: May 30, 2008, 10:48:47 AM »
Now I will stand corrected on this but you should watch that.  If running diameter is different then your circumference well be different and you could load up your limited slip diff.  When dealing with circumferences you are dealing with the factor of PI
Say a tyre had, for example only, an outside diameter of 600mm.  The circumference would be PI x D = 1885.2mm
Now lets say you had a tyre with an outside diameter of 605mm.  The circumference would be PI x D = 1900.9mm
There fore the smaller diameter is going to want to spin faster than the larger diameter for the same distance travelled.
Maybe not a big issue as a spare, but if you had to drive some distance..............
Just a thought.
« Reply #36 on: May 30, 2008, 11:59:08 AM »
Correct.  Short distance only.   ;51
Not a huge worry though considering no spare at all.
Offline MADVET
« Reply #37 on: May 30, 2008, 06:53:35 PM »
4mm is pretty close so i wouldn't worry, remember we don't travell in a straight line.
The curves and turns on our roads would induce a lot more wear on the LSD than this small discrepancy.
Besides after a few good burnouts with those 295's the diameter will probably be the same as the spare.:22
NOW WE'RE TORQUING!
« Reply #38 on: May 30, 2008, 07:42:16 PM »
Sure, but the majority of normal driving is in a straight line, and diffs are not designed to "differentiate" for wheel rotation speeds continuously -- only for the short periods during cornering.
Offline MADVET
« Reply #39 on: May 30, 2008, 08:17:56 PM »
True, but it's only 4mm in diameter we're talking here, or if you like 2mm of tread depth, easily fixed 69DR style.;46
    ;46;46;46
NOW WE'RE TORQUING!
