Author Topic: doors move when closed  (Read 9847 times)
Offline mick
« on: February 04, 2008, 09:35:29 AM »
Hi all, Hoping someone might be able to offer a solution for me with a problem I have with my doors.
When I close the doors they close perfectly and sit well, but I can push them about another 10-15mm inwards, they spring back out again ok, but when im driving the car they rattle a little as well.
There are no rubber stops like the bonnet has, can you buy them for the doors as well ?
« Reply #1 on: February 04, 2008, 09:46:54 AM »
Hi Mick;ay
I assume that your Corvette is a C3;27
I will also assume that your door hinge bushes are OK and have no play in them;mmm
The problem you have is common and is caused by a worn door striker pin:{
If the door striker pin is ok then it is a worn or poorly fitted door main weather seal;30
If not that your door adjustment has been set up incorrectly and you don't want to go here;29
Offline mick
« Reply #2 on: February 06, 2008, 08:29:25 AM »
Hi Chromie,
                   Thanks for your reply, yep I've got a 72 t-top (as per avatar). Door hinge bushes are new and rubbers are new as well. Door closes perfect except movement.
Door striker does does move a little (internally)
So I do need a new pin then, I thought so but a wanted a second opinion.
anywhere I can buy a small item like this in Australia without having to pay frieght from the USA
Offline mick
« Reply #3 on: February 07, 2008, 06:29:51 PM »
$9.99 for a OEM pair brand new on Ebay, that will do I think. Just waiting on a frieght cost.
« Reply #4 on: February 07, 2008, 09:36:12 PM »
i think the hq holdens are the same?
