Author Topic: 1968-1982 C4 Based \"Shark\" Chassis For Your C3 Corvette  (Read 7891 times)
« on: February 03, 2008, 03:43:15 PM »
Found this at http://www.streetshopinc.com
General Description:
Only from Street Shop, we offer a new "mandrel formed" replacement chassis for your 1968-82 Corvette and is designed to fit under the stock floor-pan. This chassis utilizes the C4 1989-96 Corvette suspension, drastically improving handling and braking capability. Designed around the car's original features, this chassis allows you to "bolt on" your original body with NO modification to your C3 Corvette body.
The process of mandrel bending our 4"x2"x0.120" wall steel tubing maintains the dimension of the tubing, thereby providing the maximum amount of strength from the finished frame rail. These one-piece, formed rectangular rails are very rigid and lightweight. The end result is a frame that weighs slightly less than the original, but also one that resists the twisting and flexing common to these cars.
All chassis are finished in durable semi-gloss black powder coating and feature stock mounting for the bumpers and body, as well as the engine and transmission, which are capable of many engine / transmission combinations. Coil-over shocks are used at each wheel and provide a completely adjustable ride, while a power rack and pinion steering unit is included for quick and responsive steering.
Click This Pic To See More Shots The Standard 700 wide
Do You Have A Large Computer Screen?  You Can Now View 1024 wide Pics,
CLICK ME
[/align]
Standard Specifications:
4" x 2" x 0.120" Mandrel bent tubing.
Poweder coat finish in semi-gloss black.
CAD designed, CNC laser cut components
Mounts for 1989-1996 Corvette suspension front & rear.
Stock track width allows for use of standard offset wheels.
Mounts for front and rear bumbers using stock mid-year brackets.
Engine & transmission mounts in factory locations.
Removable transmission crossmember.
Clutch pivot bracket in stock location.
Mounts for stock mid-year core support.
Body mounts in stock locations.
Body mounts in positions #2 & #3 feature captured nuts as originals.
Accepts stock gas tank support and gas tank.
Mounts for factory spare tire carrier.
Rear suspension modifications at no additional cost!
Bolt-on without cutting fiberglass!
Available Options & Accessories :
Stock 13" front brakes.
Drilled & slotted rotors (13" front only).
Gran Sport (1996 style) front calipers (13" front only).
Powder coat rebuilt stock calipers.
Wilwood 6 piston caliper with 13" rotor front brake kt with 2 piece rotors. Also includes stock diameter 2 piece drilled & slotted rear rotors.
Streetshop Exclusive: Wilwood 4 piston caliper upgrade for stock rotors (13" front only).
Hydroboost hydraulic brake booster systems.
Power steering line kit.
Classic Auto Air systems for original A/C and non-A/C Corvettes ('58-'77)
Tremec Transmission Kits with stock shifter location.
Rock Valley stainless steel fuel tanks with in-tank electric fuel pump.
Custom wheels from American Racing, Budnik, Billet Specialties, and many more.
Most brands of tires available.
Multiple rear gear ratios available.
Offset rear sway bar available for C2 with wider rear wheels.
Flaming River Steering columns, tilt 63-69.
Turn signal harness adapters for Flaming River columns.
Griffin aluminum radiatiors with custom outlet configurations available.
LS engine harness wuth ECM controls and programming from FAST Electronics.
LS engine drive accessory package with A/C, power steering, 140 amp alternator, and billet brackets.
« Reply #1 on: February 03, 2008, 05:03:47 PM »
Nice find, Cam.
Lots to like about that, especially "Removable transmission crossmember"
« Reply #2 on: February 03, 2008, 06:49:39 PM »
All original auotomaticss have a removable croos member on C3's.  Only manuals have their cross member welded in, as far as I know.
« Reply #3 on: February 03, 2008, 07:45:05 PM »
That's true according to the Corvette Restoration Guide.
« Reply #4 on: February 04, 2008, 10:14:05 AM »
I think you'll find that's the Chassis Murray has under his C2 LS2. :v
