Author Topic: Ceramic Coatings  (Read 7253 times)
Ceramic Coatings
« on: January 04, 2008, 12:11:38 PM »
Have heard one or two of the gang here and there talking about ceramic coatings.
Found this.  Thought you may be interested.
Click This Logo To Go To Their Tech Page
[/color]
EXTRACT
Description: JET-HOT Sterling: As the name implies JET-HOT Sterling contains silver powder. This metal gives JET-HOT Sterling an improved shine without compromising on corrosion protection. Sterling shines with the best look yet in high-temp, high tech coatings. JET-HOT® Sterling™ provides lasting beauty. Its appearance shares the brilliance of chrome and the subtly of nickel. Other metallic-ceramic coatings look dull in comparison. The RMS numbers (a measure of smoothness) demonstrate how far JET-HOT has jumped ahead of other coatings. With the addition of silver powder to our exclusive formula, we have beautified our coatings by a factor of six on the RMS scale while improving performance.
JET-HOT Hi-Lustre has chrome like highly polished aluminium appearance and JET-HOT silver has satin appearance and both from the Metallic Ceramic family of coatings. Corrosion Resistance as tested in Accelerated Salt Spray tests have proven that JET-HOT last over 5 times longer than other Metallic Ceramics, more than 14 times longer than Chrome, and over 140 times longer than HI-TEMP paints. HI-TEMP Fatigue Resistance test have shown after 10-million stress cycles over 300 hours at 538c (1000F), that uncoated 403 stainless steel had a fatigue strength of 56,000 psi and JET-HOT coated 403 stainless steel was 68,000 psi.
This coating when applied to exhaust headers or manifolds acts like a thermal barrier and keeps the heat in side the headers, reducing under bonnet temperatures. Independent test conducted at Daytona Speedway showed how JET-HOT reduces under bonnet temperature. Comparative temperature readings were taken immediately after ten laps, run at between 6900 and 7500 RPM, on an engine idle at 2000 RPM with an exhaust tempt of 454c (850F). The test show that temperature of uncoated headers 1 inch from the port was 399c (750F), 2 inch above the header 121c (250F) and 1 inch above the floor pan 82c (180F), while JET-HOT coated headers were at a low 204c (400F) 1 inch from the port, 110c (230F) 2 inches above the header and 49c (120F) 1 inch above the floor pan.
Another unique feature is JET-HOT’s ‘self-repair’ quality,..........................
They also talk about coating pistons
[/color]
Ceramic Coatings
« Reply #1 on: January 09, 2008, 05:09:04 PM »
yep - worth it as it makes a difference.  They can coat pretty much anything internal and external.
Ceramic Coatings
« Reply #2 on: January 09, 2008, 06:04:14 PM »
they have got my extractors at the moment,i am getting the sterling finish,should have them back any day now,will post a pic.:ado
Ceramic Coatings
« Reply #3 on: January 22, 2008, 03:17:01 PM »
got my headers back today from jet hot..........
Ceramic Coatings
« Reply #4 on: January 22, 2008, 03:42:27 PM »
If only they stayed that purdy!
Offline Mattrix
Ceramic Coatings
« Reply #5 on: January 22, 2008, 03:44:48 PM »
bling bling, bling bling, better answer the pimpophone :D they look awesome. i don't think i want to know how much that cost... i was thinking while my sidepipes were off i should get them shined up somehow, though wasn't sure of my options or pricing or who did them.
Ceramic Coatings
« Reply #6 on: January 22, 2008, 04:13:58 PM »
just call jet hot ,they will give you a quote over the phone.that finish that i got is the stirling finish;ay
Ceramic Coatings
« Reply #7 on: January 22, 2008, 04:20:14 PM »
I can relate... ;30 ;53
