Author Topic: C4 Steering Wheel Movement  (Read 18265 times)
« on: December 12, 2007, 07:20:40 AM »
Sorry, New to forum When I looked last in subject description/message of what I wrote was wrong was still here? anyway here I go again>>
The new Vette I bought has steering wheel movement. As though who ever used it used to lever off the steering wheel when getting out of car.... The steering column / wheel moves /flex's in the column. Is this a common thing in Right hand conversion with Vettes? The car has a mirror conversion completed by Corvette Clinic in QLD.
Regards, Jethro
Offline VET-005
« Reply #1 on: December 12, 2007, 07:51:17 AM »
Think you need to be a bit more specific in what you are asking
Click Images For My Gallery
« Reply #2 on: December 12, 2007, 07:14:27 PM »
« Reply #3 on: December 12, 2007, 07:21:31 PM »
Hi Jethro;42
Your problem is common with corvettes with tilt columns;30, your tilt pivots are worn or the column is loose internally, remedy is to get your steering column serviced/repaired by someone who knows what to do and has done them before. Often the hubs where the column pivots has to be sleeved.
Hope this helps:x
« Reply #4 on: December 12, 2007, 07:30:35 PM »
Sounds like a fix. I'm from Wollongong can you advise whom I should contact to rectify the issue?
Jeff
« Reply #5 on: December 12, 2007, 09:14:17 PM »
Regards, Jethro
Sorry about that I missed this one.  Moved it here to the correct section.
Forum admin
« Reply #6 on: December 12, 2007, 09:33:02 PM »
So can anyone point me in the right direction to someone that can fix this issue in or around the Wollongong area?
« Reply #7 on: December 12, 2007, 09:47:53 PM »
Try USGM Service Parts
Ph: 02 4257 1230 (9-4pm)
Fax 02 4257 8042 (24hrs)
This is a spare parts place down that way but they should know who in the area can help you out.
« Reply #8 on: December 12, 2007, 10:09:33 PM »
Thanks Bud
Will do!
Re: C4 Steering Wheel Movement
« Reply #9 on: June 12, 2014, 09:27:53 PM »
 :bump:
Ahhhh, how time flies  December 12, 2007...... seems like only yesterday  :yap:
Offline Ausrs
« Reply #10 on: June 16, 2014, 10:04:46 AM »
who ended up fixing the column ? I ended up needing the same thing on my C4 but did it myself
« Reply #11 on: June 16, 2014, 06:26:05 PM »
As you did buddy, ended up pulling it apartment myself :)
