Author Topic: Diff X-member reinforcement kit??  (Read 12211 times)
« on: December 06, 2007, 02:23:15 PM »
Does anyone know anything about these?  What are they actually supposed to do, and are they effective?  I came accross them while looking for front diff mountings.
Since I am completely rebuilding the rear of my 73 small block, it wouldn't be hard to add them in if they are worthwhile, but I can't ascertain what they actually do, and I'm obviously using the wrong key words when searching.
« Reply #1 on: December 06, 2007, 03:22:41 PM »
I'm not sure exactly what the benefit is either.  If you don't know what it does then you probably don't need it.
If you rebuilding the whole rear end I think you'll be surprised how much better that will be anyway!
;42
Offline jdunne
« Reply #2 on: December 11, 2007, 03:43:44 PM »
If you are already rebuilding it the best thing to do is to make sure the diff cover is one of the reinforced heavy duty ones.....the can crack/break at the ears(where the bolts go in)quite easily....john;)
Offline WARFARIN
« Reply #3 on: January 31, 2008, 09:48:37 PM »
These things bolt on to the crossmember at each side of the chassis that supports the diff. There is a rubber mount there and this massive aluminium washer aledgedly reduces the movement under load. More info available at the VB&P website.
