Technical Tips
Engines - Carbies - Exhausts - Dissys
Extractors for C3
Topic: Extractors for C3 (Read 20808 times)
GoldDigger
Two Barrel
Extractors for C3
November 23, 2007, 09:25:39 AM »
I plan to put extractors on my C3 & would like to know who supplies ceramic coated to suit a 350 C3 RHD.
77CVT
Fuel Injected
Extractors for C3
November 23, 2007, 09:34:50 AM »
Unfortunately you'll have to get them custom made.
reserved
Four Barrel
Extractors for C3
November 23, 2007, 12:23:23 PM »
;eek :mmm ;eek
Have a look at Corvette Central part number 322234.
It may suit.
;27
77CVT
Fuel Injected
Extractors for C3
Reply #3 on:
November 23, 2007, 01:18:51 PM »
All that really needs to be done is for the RHS, cut the No1 tube and reroute over the top to clear the steering box. You could buy stock ones and have that side redone and save some $$.
;42
MADLT1
Extractors for C3
Reply #4 on:
November 23, 2007, 05:03:48 PM »
hi 69fan,check out liverpool exhaust centre,96023111,41 seton road,moorbank.they do quality work with mandrel bending.
Darylle
Two Barrel
I'm new here
Re: Extractors for C3
Reply #5 on:
August 20, 2017, 10:52:47 AM »
Hi all
Is there an "off the shelf" set of extractors available yet? I have been told I need to go with block huggers, can anyone suggest any other option?
Thanks Darylle
Darylle
Two Barrel
I'm new here
Reply #6 on:
August 20, 2017, 01:50:29 PM »
I just found some "castle" brand extractors to suit Holden HK-T-G with small block on engine master (CH-116A) and by the looks of it the front pipes travel horizontally back from the port (not down) I wonder if this vehicle model had similar steering box clearance issues?
Technical Tips
Extractors for C3
