Author Topic: Exchange front and rear suspensions  (Read 7354 times)
« on: April 24, 2007, 11:02:28 AM »
I am starting an exchange suspension deal for C3's:spook
The suspensions are rebushed with urethane or rubber bushes, new wheel bearings, refaced spindles and front wheel bearing hubs, relined park brake shoes, stainless steel park brake springs & levers. ;-- you will also have the choice of an old dust shield painted black or new dust shields in gold or silver depending upon your choice.;29
The suspension parts are sand blasted and painted in either gloss black or mat black depending upon your choice.;laugh
This will enable customers to do their suspension work in one day and take out all the frustrating delays and technical work.;35
For those who are interested please let me know on this forum.;43 or;26
I will have all the prices for these exchange units by Sunday 29/04/2007 as well as the terms and conditions of exchange.;27
Other parts such as stainless steel trailing arm shim kit, rear park brake cable, cable retainers, rear camber bolts, brake caliper parts e.t.c. can also be included in the exchange kit at an additional price.;27
 General enquiries;32
« Reply #1 on: April 24, 2007, 12:49:56 PM »
Ahh you finally got it soughted out.  Good one squire :bold
« Reply #2 on: April 24, 2007, 01:49:36 PM »
When I get my C3 I will be!
« Reply #3 on: April 24, 2007, 02:49:39 PM »
Set up another thread.  I want to hear more about this.  What C3?
« Reply #4 on: April 24, 2007, 03:50:05 PM »
C4 suspension even though it will not be exchange it can be that you drop off the suspension to me on a Saturday and pick it up the following Saturday.
It will be priced as a fixed amount the C4 suspension can only be done in urethane. :24The wheel bearings cannot be serviced;38
« Reply #5 on: April 24, 2007, 03:58:37 PM »
I miss my old '77 - I want a chrome bumper big block.  Nothing in the pipeline........yet.  ;-)
« Reply #6 on: April 29, 2007, 07:04:00 PM »
Ok finally I have got the prices for the exchange suspension rebuild assembly's;42 these prices are for C3's (and most c2's)
Prices are as follows
Front upper & lower bushes fitted "urethane" (no ball joints)
This will mean that you refit your old ball joints on the reconditioned suspension.
The "A" arms will be sand blasted/tested/painted/rebushed nothing more
The above is $1,563.76 + G.S.T. (or $1,368.80 + G.S.T. in rubber)
If you want the lot for the following
Front upper & lower bushes fitted "urethane", new ball joints, front wheel bearing hubs with new bearings
The "A" arms will be sand blasted/tested/painted/rebushed and new ball joints fitted, the front wheel bearing hubs will be refaced and sand blasted and painted
All the above $2,649.52 + G.S.T. "urethane" (or $2,454.56 + G.S.T. in rubber)
The extras which will be priced as requested for the front suspension are
Spindles, caliper mount brackets, steering arms sand blasted and painted. tie rod ends, disc rotors and disc machining, calipers, disc pads, bump stop rubbers,idler arm, pitman arm, front coil springs, front sway bar parts, steering control valve assembly (where fitted), upper and lower inner control arm bolts/washer kits, brake hoses, rotor splash shield, wheel bearing hub cork gasket, etc.
Note there is a charge for non exchange parts due to damage or no part to exchange
The rear suspension is as follows
Exchange parts in a kit are
trailing arms fully assembled with wheel bearings & bushes (with out park brake parts) in urethane
camber struts with bushes in urethane
front differential mount bush kit in urethane
spring to trailing arm bushes in urethane
Park brake cable guide bushes.
All the parts are sand blasted/tested and painted, the rear spindles are refaced
All the above is $2,644.23 + G.S.T. (or $2,837.60 + G.S.T. in rubber)
If you want all the rear including park brake shoes relined, stainless steel park brake spring kit and stainless steel trailing arm shim kit, the kit is $3,072.39 + G.S.T. (or $3265.76 + G.S.T. in rubber)
yes the rubber rear suspension is more than urethane.
Extras are
disc rotors and disc machining, calipers, disc pads, bump stop rubbers, rear spring, rear sway bar parts, brake hoses, rear brake pipes, rotor splash shield, rear lower shock mount pin, etc.
These exchange kits come with an extensive warranty.
;35
Hope these prices help.
