Author Topic: Corvette Alterations. A sample of what they stock.  (Read 8088 times)
« on: January 31, 2007, 07:42:50 PM »
G'day gang.
Me....................again.:22
I spoke to Corvette Alterations, one of our majour sponsors here on the forum, a while back saying that if he was to pass on to me in stages some samples of what he stocks I would post it for him as a token for all the free support he has been offering our members here on the forum, on the phone and lately at his point of business.
Amongst their selection of parts, which cover a wide range of corvette eras, they keep a great variety of C3 parts. Which is a good thing for our club since the bulk of our members are C3 owners. ;39
Here is a small list of parts of what they now keep in stock.
1) 1968-72 complete windscreen frame from the very top all the way down to the sill
2) 1970-77 sills
3) Radiator support panels 1969-82
40 Radiator assembly’s Big Block & Small Block 1969-72
5) Heater cores 1968-82 A\C and non A\C
6) Door glass both coupe & convertible 1968-82 tinted astro-ventilation and replacement
7) A\C condensers
8) A\C evaporators
9) Rocker panels 1968-82 (except 1978 anniversary)
10) Sill panels 1968-82
11) Full range of radiator hoses 1968-82
12) Full range of sunvisors (black) 1968-82 including mirrors and hardware
13) Weather seal kits body roadster 1969-72
14) Weather seal kits soft top 1968-75
15) Hood hinges
16) Rear spindle flanges 1963-79
17) Halfshaft flanges 1963-79
18) Door trims “deluxe” 1970-76
19) Front grilles full range
20) Lights, lamps, lenses, lens hardware etc complete range 1968-82 (except 1980-82 left front park-indicator assembly)
21) Full range of alternator brackets 1968-82
22) Full range of P\S brackets
23) Full range of A\C mount brackets
More items will be posted as they come to light.
Click HERE to go to their website.
Many thanks Scott for you help and guidance with our car troubles.
You can see some pics of a very small sample of what they stock HERE plus ads and links to our  advertisers.
Cam ;42
[/align]
« Reply #1 on: February 01, 2007, 10:15:29 AM »
Thanks Cam;42
You are quick as usual I only sent that to you yesterday
:drink
« Reply #2 on: February 14, 2007, 10:44:13 PM »
G'day gang.  Here is the latest list of goodies that Corvette Alterations who, confirmed by a supplier in the USA, is the largest Corvette parts buyer in Australia with over 4,000 items kept in stock.
1/ 1968-72 complete windscreen frame from the very top all the way down to the sill (second hand)
  2/ 1970-77 sills (second hand)
  3/ Radiator support panels 1969-82
  4/ Radiator assembly’s Big Block & Small Block 1969-72
  5/ Heater cores 1968-82 A/C and non A/C
  6/ Door glass both coupe & convertible 1968-82 tinted astro-ventilation and replacement
  7/ A/C condensers
  8/ A/C evaporators
  9/ Rocker panels 1968-82 (except 1978 anniversary)
10/ Sill panels 1968-82
11/ Full range of radiator hoses 1968-82 (all GM type)
12/ Full range of sunvisors (black) 1968-82 including mirrors and hardware
13/ Weather seal kits body roadster 1969-72
14/ Weather seal kits soft top 1968-75
15/ Hood hinges
16/ Rear spindle flanges 1963-79
17/ halfshaft flanges 1963-79
18/ Door trims “deluxe” 1970-76
19/ Front grilles full range
20/ Lights, lamps, lenses, lens hardware etc complete range 1968-82 (except 1980-82 left front park/indicator assembly)
21/ Full range of alternator brackets 1968-82
22/ Full range of P/S brackets
23/ Full range of A/C mount brackets
24/ Full range of C3 brake parts
25/ Full range of C3 suspension parts
26/ C4 front and rear disc pads
27/ C3 front and rear sway bar kits
28/ C3 body mount kits
29/ C3 seat belt reinforcements
30/ C3 water pumps
31/ C3 starter motors
32/ C3 expansion tanks, straps & mount bracket.
33/ C4 wheel bearing assembly’s (GM type)
34/ C4 thermo fan blades
35/ C4 thermo fan motors
36/ C3 power window motors
37/ C3 cruise control units
38/ Full range of C3 steering column parts
39/ C3 Fibreglass panels such as front and rear bumper bars, inner guards, hoods, Indy front spoilers, door skins
40/ C3 spare wheel parts
41/ Early C4 rims
42/ C3 rims, trim rings & centre caps
43/ Original heater boxes A/C type
44/ Original steering column mount brackets
45/ Original pedal assemblies with mount cages
46/ C3 centre instrument cluster bezels including ones to take a radio/CD player
47/ 1978-82 printed circuit boards for the centre instrument cluster and speedo/tacho
48/ C3 Centre instrument cluster lenses, speedo/tacho lenses
49/ C3 Door glass weather seal
50/ Complete range of C3 headlight parts
51/ C3 vacuum hose kits
52/ 1968-71 fibre optic looms front and rear as well as the console lenses & bezel
53/ 1968-72 rear window storage tray (second hand)
54/ C2 & C3 small block exhaust manifolds
55/ 1977-82 shift console plates “full range”
56/ C3 emblems full range
57/ C3 & C4 Door mirrors
Scott also informed me:-
"Also I am prepared to offer to our members an interior trim package which is normally from $10,500.00 + G.S.T.
This package gives you everything and I mean everything to do with interior trim (except left & right dash boards fro right hand drive Corvette’s)
The price is based on 1970-75 roadsters as coupes are extra due to more trim being required.
They will save about $1,750.00 off the $10,500.00 which will bring the cost down to $8,750.00 + G.S.T.
And if I get four or more orders I will give a further 5% off these items.
If the members want a list of parts in the interior trim package let me know and I will send you one.
There are 35 different items in this package for a 1970-75 roadster
If any other type of C3 or coupe or a C1, C2 or C4 requires a price let me know and I will do one."
02 9971 8218
[/align]
