Author Topic: CONVERT MANUAL TO AUTO T700  (Read 11448 times)
Offline L71
  • 69 L89 Auto
  • Mood: :-)
« on: December 18, 2006, 07:26:03 PM »
Has anyone out there put a t700 into a c3 , I’m sure there’s a kit out there somewhere seen it in a heap of mags but forgot where  & couldn’t be bothered going through hundreds of Vette mags.  The fitting up of the box isn’t the issue its all the rest of it, want to ditch the Muncie & go drag shift , also making the cross member removable for ease of working on , John 0407 012359
« Reply #1 on: December 19, 2006, 02:27:40 PM »
Brutus will have the info - I think he may even have an R200(?) box that will do the job too!
Send him a u2u.
ettev87
  • Guest
« Reply #2 on: January 24, 2007, 09:02:58 PM »
I have a shifter kit from Ecklers in the States that is surplus to my needs.
Brand new, make an offer.
I should add;
Besides the "shift conversion" kit from Ecklers which has the detent plate, cable hardware and indicator plate. I have the shift lever and all associated brackets etc.
I am changing my auto to manual.
Also available is new B&M auto drive plate, new B&M hi-stall converter and original 3 speed trans with B&M shift lit installed.
All of the above never installed.
« Reply #3 on: January 31, 2007, 10:06:56 PM »
Read
http://www.nswcorvettes.com.au/forum/viewthread.php?tid=286
Any half decent welder could mod the existing trans mount to suit.
Get driveshaft shorterned ,
Late 4 spd ,T350, T700, yokes the same.
« Reply #4 on: February 21, 2007, 09:05:36 PM »
I am intending to do my car at the end of the month have a couple of articles with gearbox lenght tail shaft yoke etc
 Geoff 0417473492
