Author Topic: Diff and gearbox numbers  (Read 16824 times)
Offline GPJ80
« on: November 26, 2006, 05:41:07 PM »
Hi there , trying to determine what diff and gearbox i have in my 1970 , The diff numbers are 1CA04 20 70 W and was wondering if anyone knows where the numbers can be found on the 4-speed gearbox , Its probally just the standard M21
« Reply #1 on: November 26, 2006, 06:35:38 PM »
Do u have  a letter missing after the CA? Can you comfirm the above numbers?
Have you got the protecto plate of the vehicle?
« Reply #2 on: November 26, 2006, 06:41:27 PM »
 If the "0" is actually an "O" and not any other character, then what you have is a 3.70:1 positraction axle originally used with a 350 cid engine. That means the engine would have to be an L-46 or an LT-1
The transmission production code and VIN derivative will be found stamped vertically on the right side (passenger side) of the MAIN CASE just forward of where the extension housing/ rear bearing retainer plate attaches. The production code will begin with a "P" and will end with an "A", "B", or "C".
A= 2.56:1 wide ratio (M-20)
B= 2.20:1 close ratio (M-21)
C= 2.20:1 HD close ratio (M-22)
NCRS SOURCE
Offline GPJ80
« Reply #3 on: November 26, 2006, 07:30:22 PM »
Yeah not sure , the numbers on the diff are how i have seen them , Its hard to see whether or not its  a O or a 0 because all the O are the same size and shape , Whats the protecto plate , And the gearbox number i checked it , its POE04B . How can i find out what motor it came out with because i know now that the 350 that is in it is a CKW motor out of 72 model but has had LT1 Spec done to it
« Reply #4 on: November 26, 2006, 07:35:32 PM »
 Whats the protecto plate?
The Protect-O-Plate was furnished with all chevrolet cars (65-72)and was a metal plate imprinted at the assembly plant. The plate contained information on various standard or optional equipment. You may determine from the imprinted information on the plate the type of engine, transmission, rear axle, exterior color, the month the vehicle was produced, and other basic vehicle information.
Note: This plate was included with the warranty book and was not attached to the car.
« Reply #5 on: November 26, 2006, 07:39:11 PM »
Whats your VIN number?
Offline GPJ80
« Reply #6 on: November 26, 2006, 07:47:28 PM »
No i dont have the protect o plate , didnt know about that , I know they got info on top of the fuel tank but have not check it yet , probally have to drop the fuel tank , The VIN number is 194370S412218
« Reply #7 on: November 26, 2006, 07:54:05 PM »
mate i am afraid the only way you are going to tell what engine was in it is by the Protect-O-Plate...unfortunatley Vin numbers for 1970 does not identify the engine...
Convertible Serial numbers ranged from 194670S100001 to 194670S117316
Coupe Serial numbers ranged from 194370S100001 to 194670S117316
Position Character Description
1 1 Chevrolet Division
2 9 body series: Corvette
3 4 type of engine: V-8
4 & 5 67 convertible
37 coupe
6 0 1970
7 S Assembled in St. Louis, MO
8 to 13 100001 to 128566 production sequence
Offline GPJ80
« Reply #8 on: November 26, 2006, 08:13:04 PM »
Does the paperwork on top of the fuel tank tell me anything about engine and so on , But dont like my chances of it still being there , You would think someone would keep records of these cars hey , Oh well . I wonder if i can contact them in the USA and see if they can give me anything .
« Reply #9 on: November 26, 2006, 09:09:13 PM »
this is mine, it is like credit card size...
« Reply #10 on: November 26, 2006, 09:17:09 PM »
I dont think it would tell you anything dude unless it had an option engine...and good luck trying to locate these informations
this is an exmple (mine)
tells you the colour of the trim
radio option
power steering
etc...
« Reply #11 on: November 27, 2006, 06:02:26 PM »
Nice work Joe. ;42
Might have a little project for you for info to put in our mag and on our web site.  I'll give ya a buzz over the weekend. ;35
« Reply #12 on: November 27, 2006, 10:04:35 PM »
Originally posted by Cameron 77C3
Nice work Joe. ;42
No worries Cam...If I could help please let me know
